04 Accord V6 Brake Issues
I'm having an issue with my brakes. I replaced the brake calipers, brake pads as well as the Master Cylinder. Now, my TSC, ! and Brake dash lights are ON. When I try to bleed the brakes, I only have pressure on my FL and RR brakes. The FR and RL brakes have no pressure. Not sure what the issue is, did not have this problem before I changed the calipers and brake pads.. How do I know if its a bad proportioning valve or something else?
Thank You
Thank You
Re: 04 Accord V6 Brake Issues
This link might help to get the lights off, but the "no pressure" issue sounds like the master cylinder or proportioning valve.
http://www.driveaccord.net/forums/sh...78&postcount=5
I replaced the Master Cylinder, so I sounds like it may be my proportioning valve. Is there a way to overhaul or restore the proportioning valve? Or it just needs to be replaced with a new one? Is the proportioning valve the same as this:
http://www.hondapartsunlimited.com/a...er=46470s5te01
#26 - 46470-S5T-E01 JOINT, FOUR-WAY
Last edited by juniornapeahi; 07-06-2014 at 03:06 PM. Reason: forgot to add link and verify if its the same part
This is a TCS reset procedure. Don't know if it will help.
jofat91
05-14-2011 10:40 PM
byronl
01-22-2008 12:55 PM
