crank but not starting
Ok so here's what happened, turned off car went to eat came back out, not starting. I got a check engine light for misfire in cylinder 3. Cranks but wont start and I have no idea what to do.
Here's what I replaced trying to get it to work:
Cap n rotor
Ignition control module
Ignition coil
Main relay
Spark plugs
Im running out of things to replace, its like its not getting gas but I smell gas in the throttle body and hear the fuel pump prime? Any help would be nice
Cap n rotor
Ignition coil
Main relay
Spark plugs
Re: crank but not starting
Back to the basics check of spark. Crank engine then pull plugs and check if they are wet with fuel. If you have those check for compression.
