Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
07 Acura TL type S Tire pressure monitor system
Old 06-21-2014, 12:56 AM
dragonkx's Avatar
Default 07 Acura TL type S Tire pressure monitor system
a few months ago out of no where my TL just gave me an error code TPMS error. I was wondering where exactly is the TPMS unit located in the car? I tried the parts diagram and it doesn't really tell you where its located. Any ideas on how to fix it? Is it the unit itself or the ones on the tires? How are they programmed anyways, incase the tires need to be rotated.
Old 06-21-2014, 01:23 AM
Black R's Avatar
Default Re: 07 Acura TL type S Tire pressure monitor system
The monitors are inside the wheels...
Old 06-21-2014, 10:22 AM
dragonkx's Avatar
i always thought it worked like a transmitter and receiver, so shouldn't there be a receiver
Old 06-21-2014, 10:33 AM
Black R's Avatar
What's the error you're getting?
What wheels are you using?
Old 06-21-2014, 11:32 AM
dragonkx's Avatar
they are stock type s rims. all of a sudden they just stop transmitting to my dash, and an error message pops up tpms error. I checked the pressure using the tpms and all of the tires doesn't seem to be transmitting, all at 0. but I heard that if one is bad, all of them don't work.
Old 06-21-2014, 12:56 PM
Black R's Avatar
I found this on acurazine:
http://tl.acurazine.com/forums/showt...ght=TPMS+Error
Good luck!
Old 06-22-2014, 10:28 PM
dragonkx's Avatar
thanks for the input, but from that link. basically what most of them did was try to erase the code. and I would tried most of what they said, remove battery cable, check tpms fuse, even ran an obd2 scanner, don't seem to work. all that's left is to run a (Hds) Honda diagnostic system, which I don't have and would probably cost me $200, just so they can plug it up and erase the code.
Old 07-31-2014, 12:47 PM
guiltyxxspark's Avatar
The odds of it being the receiver are almost none. The wheel units go out all the time. I've had my RR unit out for a while. It's annoying getting the error on start up.
crv733
Honda CR-V & Element
12-12-2017 01:30 PM
Feriofan
Acura TSX
02-06-2011 02:55 PM
billy ruben
10-13-2010 04:26 PM
mfburger
11-30-2008 11:41 AM
EJ1 wilcox
Suspension & Brakes
02-28-2006 06:27 PM
Quick Reply: 07 Acura TL type S Tire pressure monitor system
