Old 10-30-2002, 07:09 PM   #1
dynomax27
dynomax27's Avatar
Default does white smoke from exhaust = burning oil
Well the civic is finally boosted. I fixed all of my exhaust leaks. Now it seems that im burinig oil or something. After a nice and easy 15 min drive I still see white smoke comming from my car. I know its normal when its cold outside and the car is cold but after 15 min i shouldnt be seeing white smoke. What do you guys think. Also it looks like my turbo is leaking oil too. When i look at the turbo from the bottom i can see oil seaping through the sides where it connects to the turbine.
95 H22a Civic
dynomax27 is offline   Reply With Quote
Old 10-30-2002, 07:10 PM   #2
Kamin
Kamin's Avatar
Send a message via AIM to Kamin
Default Re: does white smoke from exhaust = burning oil (dynomax27)
white = coolant
blue = oil
brown/black = fuel
Kamin is offline   Reply With Quote
Old 10-31-2002, 06:09 AM   #3
Benj
Benj's Avatar
Default Re: does white smoke from exhaust = burning oil (KAMiN)
Maybe you've got a blown head gasket?
Benj is offline   Reply With Quote
Old 10-31-2002, 07:24 AM   #4
nsxmatt
nsxmatt's Avatar
Send a message via AIM to nsxmatt
Default Re: does white smoke from exhaust = burning oil (Benj)
Most people mistake white for the blue/white type hue that usually comes from burning oil. My guess is if you just put the turbo on, the turbo is leaking oil, and now it starts blowing smoke, it's the leak. Fix the oil leak and see what happens.
93 Civic SIR-S - Real Deal RHD
05 Lotus Elise
2009 Civic SI
nsxmatt is offline   Reply With Quote
Old 10-31-2002, 07:45 AM   #5
Kamin
Kamin's Avatar
Default Re: does white smoke from exhaust = burning oil (nsxmatt)
this is true
coolant burns WHITE
oil is light blue.
check your seals for the feed and return line on the turbo.
Old 10-31-2002, 12:20 PM   #6
dynomax27
dynomax27's Avatar
ok thanks. the turbo is leaking oil. Should i just say f-it, rebuild it, or get a new one. i really dont want to spend any more money tho.
95 H22a Civic
Old 10-31-2002, 02:57 PM   #7
Bigjon
Guest
Posts: n/a
What would be the first thing to check if you car was burning oil?
Old 10-31-2002, 08:41 PM   #8
civicsitek GanGsTa
civicsitek GanGsTa's Avatar
Send a message via AIM to civicsitek GanGsTa
Default Re: does white smoke from exhaust = burning oil (Bigjon)
Fist thing to check would be how fast you are losing oil. If you are burning it, your oil level will slowly drop.
We have now entered a period in history where we no longer have inalienable rights; we are merely recipients of heavily restricted, government granted privileges that can be receded on a whim. Our Constitution as amended has been effectively rendered null and void. The republic no longer exists as intended.
Signature Required.
civicsitek GanGsTa is offline   Reply With Quote
Old 10-31-2002, 08:46 PM   #9
Evil_Wizard
Evil_Wizard's Avatar
Send a message via AIM to Evil_Wizard
Default Re: does white smoke from exhaust = burning oil (civicsitek)
Maybe your radiator needs to be upgraded to much pressure on it with the turbo now. Having a harder time cooling the engine.
Oil leak?What oil leak? That's just sweat from all that horsepower!
Evil_Wizard is offline   Reply With Quote
Old 11-01-2002, 02:40 PM   #10
dynomax27
dynomax27's Avatar
Default Re: does white smoke from exhaust = burning oil (Extreme_Hybrid_Hatch)
My radiator actually has a big dent in it form a rock. There are no leaks tho, but it probably does slow down flow.
95 H22a Civic
02, burning, car, civic, drip, exhaust, form, h22a, honda, losing, neon, oil, smoke, smoking, white
