New to forum
Old 06-18-2014, 07:23 AM
newtotech's Avatar
Default New to forum
Hello, have 2002 Honda Accord V6 3.0L 95000km, taking to shop for a timing belt replacement. I am having difficulty determing what parts should be replaced. Pulleys -do I have 2,3 or 4 pulleys. I am finding Idler pulley, adjustor pulley, tensioner pulley, and a hydraulic pulley. Also see idler roller/pulley and tensioner roller/pulley - is the roller and pulley one and the same or 2 seperate parts? I wish to replace all pulleys in the tear down area.
When requesting a timing belt replacement is the tensioner part of that or do I specifically need to request to replace that part.
Seals - crankshaft seal, camshaft seal, front balance shaft seal, oil pump gear housing seal, timing cover seal, rear balance shaft housing o-ring and distributor shaft o-ring. Again are some of these seals part of the timing belt replacement,and if not which should be replaced? Will do water pump and serpentine and power steering belt.
Any recommendations/advice appreciated. Thanks
Old 06-19-2014, 04:16 PM
ry_mass's Avatar
Default Re: New to forum
hello. i am an owner of a 1998 civic that i am having electrical problems with. i have a new battery in it but if turn off the car after not driving far it will not restart . i think the alternator is not recharging the battery and sometimes it dies while i'm just driving down the road. don't know what to do .
crvglenn
Honda CR-V & Element
08-20-2017 01:44 AM
Wingman00SI
01-21-2012 12:04 PM
voithofer
07-16-2009 01:24 PM
i-spit-hotfire
05-21-2009 02:51 PM
92sleeperh22a4
10-18-2007 02:23 PM
Quick Reply: New to forum
