Old 10-30-2002, 04:31 PM   #1
grenthang
grenthang's Avatar
Default mini me swap
is putting a 1.6 head on a 1.5 worth the trouble
R.I.P B16 14.7 96mph http://images.honda-tech.com/set1/smile/emsad.gif
R.I.P B16 to 9grand daily http://images.honda-tech.com/set1/smile/emsad.gif
b18c sold:-)
Killer K;-) 218hp and 173tq
grenthang is offline   Reply With Quote
Old 10-30-2002, 04:34 PM   #2
Dark Halo
Dark Halo's Avatar
Default Re: mini me swap (grenthang)
....no
I don't drive fast...I fly low
Dark Halo is offline   Reply With Quote
Old 10-30-2002, 04:41 PM   #3
EG_HB
Send a message via AIM to EG_HB
Default Re: mini me swap (webbman44)
....no
[img]http://images.honda-tech.com/set1/smile/emdgust.gif[/img]
EG_HB is offline   Reply With Quote
Old 10-30-2002, 05:53 PM   #4
splitime
splitime's Avatar
Send a message via AIM to splitime
if you can get the parts at a decent price i would disagree with the "no" posts.
I did one on my VX block and its a great temporary setup, I'm concentrating on suspension and such now until money for a swap develops. It'll give you decent gains, dont expect a huge huge difference, its noticable and a fun difference, but not like a swap.
"Or maybe it was just bling and he had a little tiny dick and needed a way to impress the bitches." - CRX Lee
"Street Racing is like kissing your sister.... it just doesn't make any sense."
splitime is offline   Reply With Quote
Old 10-31-2002, 12:29 AM   #5
madhatch
madhatch's Avatar
Default Re: mini me swap (splitime)
the 1.5 should be really noticable, get a y8 headgasket it is thinner. But you can ick up a z6 for 400 bucks at the slavage yard
its not a turbo but it'll hold its own
madhatch is offline   Reply With Quote
Old 10-31-2002, 12:50 AM   #6
LB CRX
Send a message via AIM to LB CRX
Default Re: mini me swap (madhatch)
does putting the z6 head on a 1.5 block give you better compression than using a straight z6?? im thinking about doing this for a temporary set up too.
"There is a replacement for displacement, its called vtec!"
88 crx si R.I.P
b16a5 y1 tranny
ice man race intake, JG throttle body, type R manifold, CTR cams, JG cam gears, .20 milled head, ITR DC 4-1 headers, 2.5' piping, dynomax exhaust, ACT 6 puck, B&M FPR, Apexi vfac
LB CRX is offline   Reply With Quote
Old 10-31-2002, 05:50 PM   #7
civic dx
civic dx's Avatar
Send a message via AIM to civic dx
Default Re: mini me swap (LB CRX)
i think you should go with the d16 because the bottom end on the 1.5 isn't good enough for future mods
civic dx is offline   Reply With Quote
Old 10-31-2002, 06:02 PM   #8
ghettocrxsi
ghettocrxsi's Avatar
Default Re: mini me swap (civic dx)
put the z6 head on with a 2mm head gasket and boost it... get pretty good gain.. from about 6 lbs
Current Ride
2007 mugen top s2k
ghettocrxsi is offline   Reply With Quote
Old 10-31-2002, 08:09 PM   #9
Evil_Wizard
Evil_Wizard's Avatar
Send a message via AIM to Evil_Wizard
Default Re: mini me swap (ghettocrxsi)
No not at all. You can get a D16Z6 motor from the junkyard for like 300-400 dollars. Why waste time and money on just doing a head swap and hoping to get as much power?
Oil leak?What oil leak? That's just sweat from all that horsepower!
Evil_Wizard is offline   Reply With Quote
Old 10-31-2002, 08:35 PM   #10
95hbMatt
95hbMatt's Avatar
Yes if using the d15 dx block such as the d15b7....it will yield higher compression due to the dx's pistons...and like posted above use the y8 head gasket to bump up your compression a few more points.....some people also use zc pistons in a mini me setup and have seen impressive gains...and some say the zex cam works wonders also....
so, all in all, a d15 block and an z6 head should put out more power than a straight up z6 Click the image to open in full size.
<U>Vouch Thread</U>
<U>Good Sellers List of HT</U>
<U>Sold my baby=( </U>
95hbMatt is offline   Reply With Quote
Old 11-02-2002, 03:14 PM   #11
low-tech assassin
low-tech assassin's Avatar
Default Re: mini me swap (95hbMatt)
I agree; taking into consideration the compression gained from doing the 1.6 head on a 1.5 block and using the head gasket from the y8 will bump it even higher, i'd say that you would see more from that than a full d16 swap. Also, most people can find the head and gaskets for cheaper than they can find the total swap, i found one for $50 and i know where there alot more where that came from.... good luck finding a full swap of anything cheaper than you can find a head and gasket to swap.
[img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
'91 CRX DX 5sp, So green you cant look directly at it.
If I show up at your door, chances are, you did something to bring me there. [img]http://images.honda-tech.com/set1/smile/emsmile.gif[/img]
low-tech assassin is offline   Reply With Quote
Old 11-02-2002, 04:38 PM   #12
importboi22
importboi22's Avatar
Send a message via AIM to importboi22
Default Re: mini me swap (low-tech assassin)
how would you go about wiring up the vtec on the mini me swap?
importboi22 is offline   Reply With Quote
Old 11-02-2002, 04:44 PM   #13
Simple
Simple's Avatar
Default Re: mini me swap (importboi22)
Very carefully Click the image to open in full size.
id go with everything stock, use an EX harness with an EX ECU, and just hook everything up normal if it was a EX. should work right guys? plus Vtec switches, herd very bad things... i say stick with stock
Will Swap Motors For Beer, yup, ive actually done it
Simple is offline   Reply With Quote
Old 11-02-2002, 04:47 PM   #14
importboi22
Default Re: mini me swap (Searching...)
i was juss wondering if i could run a wire from the vtec solenoid to the stock DX harness because thats all i need to wire rite? or will that not work ..... does anyone have a EX 96-98 harness they wanna sell me Click the image to open in full size.
50% Filipino 50% Dutch 100% American!
Old 11-02-2002, 04:50 PM   #15
Simple
Simple's Avatar
yea you can do that too, but stock is less of a headache but whatever floats your boat Click the image to open in full size.
Old 11-02-2002, 05:41 PM   #16
lazy bum shaughn
Send a message via AIM to lazy bum shaughn
What about in a 88-91 Civic?
lazy bum shaughn is offline   Reply With Quote
Old 11-02-2002, 05:58 PM   #17
95hbMatt
95hbMatt's Avatar
if you want to use your stock ecu you can use a summit racing rpm switch...to can set it up to activate at any rpm....i have one for sale btw never used...
check out this link for a how-to and it talks about the summitt rpm switch... Click the image to open in full size.
http://crx.honda-perf.org/articles/z6swap/z6swap.html
[Modified by 95hbMatt, 6:58 PM 11/2/2002]
<U>Vouch Thread</U>
Old 11-02-2002, 05:59 PM   #18
95hbMatt
95hbMatt's Avatar
or you can spend the cash and get a vtec controller....the rpm switch is much cheaper tho...
<U>Vouch Thread</U>
Old 11-03-2002, 08:33 AM   #19
grenthang
grenthang's Avatar
can't i use Ls pistons to bump the compresson a little more
b18c sold:-)
Old 11-05-2002, 09:12 PM   #20
ek_b16
ek_b16's Avatar
Hey alittle more info on that swap. I have a d15b dx motor and a z6 head. what is needed and what has to be done the complete the swap?? Can anyone advice me on how to do the steps or have any info. anything is helpful..
ek_b16 is offline   Reply With Quote
Old 11-06-2002, 08:14 AM   #21
95hbMatt
95hbMatt's Avatar
Default Re: mini me swap (92taillights)
i posted the link above Click the image to open in full size.
<U>Vouch Thread</U>
Old 11-06-2002, 08:45 PM   #22
skud_dusty
skud_dusty's Avatar
on the 88-91's or any setup that uses a vtec controller, how do you richen the fuel mix? wouldn't you run dangerously lean if you just had vtec engage with lets say an 88-91 si ecu, or any non vtec ecu? im doing something close to this, and was wondering on my options on how to make vtec engage SAFELY
poop fire
Originally Posted by pdxine View Post
Screw your bear mounted cavalry, you have fire monsters that want to devour you.
skud_dusty is offline   Reply With Quote
Old 11-06-2002, 10:12 PM   #23
madhatch
madhatch's Avatar
Default Re: mini me swap (skud_dusty)
you should be able to monitor and change fuel with the vafc, that would allow you to run your dx computer. I got an ex computer for mine. as far as the older swaps i think a VAFC would definatly be the way to go. But, you will need an air fuel gauge and d dyno run would be benifical.. about a 400 dollar investment...
321046, solenoid
