coolant temp sensor help
So i replaced my rear main seal and my coolant temp sensor stopped working. Was working fine before we replaced the seal. i have replaced the actual sensor, ive replaced the coolant temp pigtail, i checked the connector for the gauge and the wires dont look to be pinched/damaged. And its still not working... any idea what it might be is there a fuse or a relay i might have blown, and if so which one is it....
any write ups will be helpful
EFB055
Re: coolant temp sensor help
Did you check the coolant temperature switch or the gauge sender?
One acts as a switch to turn the radiator fan on, the other sends a signal to the temperature gauge.
Depending on your car/engine the gauge sender is the single wire that bolts under your dizzy. Should be part of your 02 sensor/reverse light portion of your engine harness.
I have a question regarding my coolant temp sensor. my 91 crx has a sensor with two wires but the wiring harness was swapped with one from a newer civic. those sensors only have one wire. how do i solve this problem?
vtecaccord 1
12-07-2004 05:59 AM
SPORT INJECTION
10-31-2004 10:36 PM
