VTC actuator replacement and timing issue code P0341
Old 05-29-2014, 03:05 PM
helloo's Avatar
Default VTC actuator replacement and timing issue code P0341
Had an aviation mechanic friend replace my VTC actuator due to the cold start up noise. Well, car ran like crap and went back in and the timing was off a few teeth. Fixed that and the car ran a lot better but it is still a little slow/sluggish when moving from a stop. I am still getting code P0341.
Any ideas? When we were in there the marks on the actuator and other sprocket dealio were slightly off (like maybe a quarter of a tooth as opposed to pointing directly at each other in the 3-9 o'clock position) but that is as close as we could get because moving the chain another tooth would have made it off even more.
Could valves have been bent by being off a few teeth the first time? Chain stretched?
2008 Accord 4cyl.
Old 05-29-2014, 08:44 PM
DCFIVER's Avatar
Default Re: VTC actuator replacement and timing issue code P0341
2008 Accord 4cyl.
Who told you to replace the VTC? What testing was done? Was the code there before?
Old 05-30-2014, 12:21 PM
helloo's Avatar
It was replaced because it was bad due to the cold engine start-up rattle.
Old 05-30-2014, 04:44 PM
hub_n_hun's Avatar
When the timing is slightly off like that the chain is indeed stretched. Being off that little shouldn't throw the code you're getting. Did you check your cam position sensors?
Old 05-31-2014, 06:37 AM
Lost Again's Avatar
The sensors are fine. The 0341 is for the "phase" - meaning the sensors are working but what they are "reading" is out. 99% of the time, this is do to the chain.
See recent post about this: https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/timing-chain-stretch-3206791/
Old 05-31-2014, 06:40 PM
johnsc2235's Avatar
Needs a chain n I would suggest a tensioner
Old 08-14-2014, 10:50 AM
I386's Avatar
Hi
So by replacing the timing chain and tensioner would that also help with the cold engine start-up rattle issue i am having..BTW my warranty is out.
Thanks for your time
Old 08-16-2014, 04:00 AM
Lost Again's Avatar
Originally Posted by I386
Hi
What year and engine do you have?
Are you just getting the "cold rattle" or are you getting a code - both?
Old 08-17-2014, 11:21 PM
I386's Avatar
2008 4 cycle
just cold rattle ...no code
thanks for the reply
Old 09-20-2014, 01:29 AM
Kenny Sears's Avatar
Good morning America
gamajohn
05-13-2014 01:21 PM
jvk
13
01-15-2010 08:18 PM
el_toro_de_magnifico
08-26-2008 06:21 AM
BoostFedDB8
11-17-2007 08:58 PM
luderollin
11-29-2006 08:19 AM
Quick Reply: VTC actuator replacement and timing issue code P0341
