Mahle GoldSeries on Stock H22A1 rods
Old 05-08-2014, 06:09 AM
707the89fu's Avatar
Icon2 Mahle GoldSeries on Stock H22A1 rods
I know I might know the answer
But I would like to verified with people have done it....
H22 Mahle GoldSeries pistons
Can you us them with stock Rods?....
I know stocks are press in and these mahle pistons use a
22mm High quality steel wrist pins
Old 05-08-2014, 06:38 AM
Moderator
snobordboy's Avatar
Default Re: Mahle GoldSeries on Stock H22A1 rods
H22A1 rods would have to be modified with bushings like the H22A4 rods, but if you are already going to forged pistons, an upgraded rod would probably be a good idea at the same time.
Old 05-08-2014, 07:00 AM
707the89fu's Avatar
Thank you for your feed back
Old 05-08-2014, 10:48 AM
707the89fu's Avatar
Also I'm guessing that goes the same as Type-s pistons
Old 05-08-2014, 05:29 PM
Sparksman's Avatar
^ yep need to modify a A1 rod for them as well.
Old 08-29-2014, 06:30 PM
707the89fu's Avatar
thank you!!
Project_SOHC_EX
12-19-2009 11:58 AM
turbo-crx
04-18-2008 09:08 AM
specie
03-07-2004 01:51 PM
98civicEX
08-19-2002 02:58 AM
fastludeh22
08-13-2002 07:00 AM
Quick Reply: Mahle GoldSeries on Stock H22A1 rods
