Cooling fan keeps blowing???
Old 05-03-2014, 07:41 PM
artistwantab's Avatar
Default Cooling fan keeps blowing???
Hey everyone,
When I turn the A/c on the 20a cooling fan fuse keeps blowing.
Any ideas what needs to be replaced? Or is it a short?
Thanks in advance for the help.
Old 05-04-2014, 07:35 AM
Global Moderator
tech8's Avatar
Default Re: Cooling fan keeps blowing???
You probably have a short.
What year is your CR-V?
Old 05-04-2014, 02:31 PM
Its an 2005 element.
Old 05-04-2014, 05:20 PM
Global Moderator
tech8's Avatar
The under-hood Fuse No. 4 (20A) protects the radiator fan relay and fan circuit.
The short can be either with the radiator fan wiring, the radiator fan relay, or wiring coming from either the PCM or radiator fan switch.
1. Try this. Unplug the radiator fan motor gray connector. This should be attached to the radiator fan shroud. Turn on the A/C, does Fuse No. 4 still blow?
If it doesn't blow with the radiator fan disconnected, then the short is probably at the radiator fan motor or the section of the wiring.
2. If it still blows, then it may be the relay or wiring before or after the relay.
At the bottom of the radiator is the radiator fan switch. Unplug the 2P gray electrical connector from the fan switch. Use a piece of wire or small paper clip and jump the two terminals on the gray harness connector. Turn the ignition to ON, does Fuse No. 4 blow?
Old 05-04-2014, 05:47 PM
OK.
So 1st I was mistaking it is the 30a Condenser Fuse that blows.
I followed you instructions anyways and the fan on the passenger side when disconnected does not blow the fuse. Seems that fan is the issue.
Old 05-05-2014, 07:35 PM
Before I move forward I want to make sure I am moving forward correctly.
Old 05-05-2014, 08:22 PM
Global Moderator
tech8's Avatar
With the A/C turned on, if the under-hood Fuse No. 1 (30A) doesn't blow with the A/C condenser fan disconnected; but, the fuse blows with the fan connected, then the condenser fan motor or condenser fan wiring is suspect. First, examine the condenser fan's wiring closely.
Old 05-06-2014, 05:04 AM
shermanyang's Avatar
I just fixed my brother-in-laws 2005 civic with the same issue. Turned out to be a bad fan motor after checking everything. We replaced the fan itself and now we have no issues. Just a thought...
Old 05-06-2014, 06:31 PM
Thank you.
Two questions?
Best online resource for the fan motor?
Looking I see the the fan AND motor can catually be as much as JUST the motor.
What would you recommend? Hoping to order tonight to arrive before the weekend.
Old 05-07-2014, 05:44 AM
I just ordered one off of ebay. I bought a cheapo slim fan on ebay for $20 and connected it using the old connector off of the old fan.
Old 05-12-2014, 09:49 PM
Thank you. Got it and works like a charm.
Old 05-13-2014, 07:06 AM
was it the fan itself then? same issue I ran into?
Oknoe.
05-06-2010 03:43 PM
95ProjectEJ1
15
02-01-2007 03:09 PM
iphatcrxi
06-14-2006 10:52 AM
Quick Reply: Cooling fan keeps blowing???
