Spindle's balljoint replacement?
Old 04-23-2014, 06:55 PM
PrettyMuchBoned's Avatar
Default Spindle's balljoint replacement?
Am considering going back to scrap yard, but I know two tegs already had the passenger side knuckle missing..
Is there a proper way to remove the balljoint? I tried pressing it out after removing the retainer clip, but that thing is wedged in there good. Tried heating it up to 250 degrees, still wouldn't budge.
Old 04-23-2014, 07:04 PM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: Spindle's balljoint replacement?
i put an impact socket over the threaded part and bash the **** out of it with a 4lb hammer.
Old 04-23-2014, 07:05 PM
B_Swapped93's Avatar
lol'z you need a BFH(big ****** hammer) and to get it in a press is a must most garages will charge you 10-20$ to press it out then in. cheaper then a BFH if you don't have one and the press 3 times over.
Old 04-23-2014, 07:30 PM
Iv always pressed em out, but that didn't work this time. I asked another dude at the shop for help since I couldn't figure it out, he couldn't get it either.
I guess tomorrow I will be taking a sledge hammer to it and practicing golf swing.
Old 04-23-2014, 08:32 PM
bfh always works, in and out. i freeze them prior to install, i cant remember the exact size of the socket i use but it fits the outside of the ball joint perfectly, and smack it in.
Old 04-23-2014, 09:39 PM
I was using I think 20mm I dont even remember from doing it 3 hrs ago.
why do you freeze them? I was thinking about using a lil anti cease or something lol
Old 04-23-2014, 10:11 PM
driguy's Avatar
Here you go, I've used this method about 3 times already:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/balljoint-replacment-autozone-free-rentals-27023-27164-a-2987276/
Old 04-23-2014, 10:31 PM
Shoulda searched balljoint instead of ball joint
Old 04-24-2014, 05:25 AM
http://s1372.photobucket.com/user/fa...5e8a2.jpg.html
thanks guys
Old 04-24-2014, 07:20 AM
freezing is an old school method for installing rubber bushings/etc without a press. causes the material to shrink.
arielb1
04-18-2016 02:38 PM
stagen
08-09-2007 03:40 AM
Sassafrass
04-24-2003 11:40 AM
gumbybum
01-31-2003 11:11 AM
maxxdout
01-05-2003 12:54 PM
Quick Reply: Spindle's balljoint replacement?
