Error code 505 & 505pd
Old 04-23-2014, 11:56 AM
laloquera916's Avatar
Default Error code 505 & 505pd
98 v is putting out error code 505 & 505pd. WTF is this? My RPMs is acting weird. Adjusting screw is way off, anyone have a write up (sticky) on how to reset properly?
Thanks
Old 04-23-2014, 02:48 PM
Default Re: Error code 505 & 505pd
Haynes manual says it can be adjusted using a screw driver.
They say to set the V at 480 (+/- 50) RPM.
(After you pull the connector off the EVAP Purge control solenoid
and maybe the connector off the IAC Idle Air Control valve too??)
If that's right, Anyone?
Old 04-25-2014, 08:06 PM
help help
Old 04-26-2014, 01:49 AM
Technical Hero
HondaPartsHero's Avatar
Old 04-26-2014, 11:08 AM
Honda parts hero, thanks. This gives me something to work with. I got a tac, but not sure how to use it. If need be, do you where I can get a cheap working IAC Valve on line? I will post up later this evening, just to keep you in da loop.
Thanks,
Old 04-26-2014, 02:28 PM
Something is not right. I cannot get the RPM to drop. I adjust the screw and can only get it to come to 1100 RPM, and it does surge a bit. I was checking the ports, bottom port when finger plug the engine speed does drop, but the upper port when finger plug, the engine shut off.
That's where I am at this moment. Any ideas, do get at me asap.
Thanks
Old 04-26-2014, 02:34 PM
Is the evap purg control solenoid valve the one that located on the fuel rail?
Old 04-27-2014, 01:05 PM
Hello anyone?
Old 04-27-2014, 03:23 PM
Technical Hero
Yes
Old 05-02-2014, 07:17 PM
Same inchalada here, double check my work and followed the same procedure from the manual above. That top port on the intake keeps shutting off my engine when I plug it up with my finger, is that related in any way to my rpm not being able to be set correctly? Im gonna try to swap out the IAC this weekend.
Any fresh ideas out for me to try this weekend?
Thanks
Old 05-09-2014, 09:59 PM
Nailed it. Swap out the IAC Valve. My old one got stuck open, I guess there is a small diaphragm in it, and it was shot up, saw the pieces flying around when I push compress air in it.
ksportizzy12
08-29-2014 06:28 AM
TUR3Ovtec
01-07-2010 02:26 PM
SLEEPIN-GSR
06-23-2009 02:06 PM
JSpecwest
12-27-2001 11:08 AM
Quick Reply: Error code 505 & 505pd
