Almost 190mph, went 187.34mph 1/2 mile. 10,026rpm 5th gear! Hondata TC doin work!
#53
Re: Almost 190mph, went 187.34mph 1/2 mile. 10,026rpm 5th gear! Hondata TC doin work!
Congrats man, Car is sounding great. Did you get to see the Lambo break his front Diff?
#56
going faster & inspiring a few folks along the way : )
Great job Myles !
.... you know, I'm going to have you look over some drawings i had for my rear defuser...kinda tricky trying to make it work with out hacking up my bodykit. lmao = )
#59
Are you still on the same journal bearing 6262? what turbo are you upgrading to? amazing car man, taking hondas to a whole new level.
#60
On another note, LOOKS like i am going to the Shift-S3ctor 1/2 mile event in Colorado end of June!
#61
Hell ya
Thinner air could give you a higher MPH
Some of the fastest production car records are set by running at highest mid-day temps, and above sea level for lower wind resistance.
#62
AS much as i have been thinking about going to that event, its too much money in such a short time. But its not 100% out of the question yet lol
#63
Myles, I got your PM. I'm not ignoring you. Just been super busy. I hope to get back to you tonight.
#64
The beauty of racing is that usually if that you usually find the money you need whether it be for an event or a part.
#65
I actually am making arrangements to cancel of of my events in june just to budget the trip out to this event.... at this point its looking like 70% chance of logistically being able to make it.
#66
#68
Looks like a new turbo is going on the car, make a little more power and doing a Final drive. Going to the 4.266, should let me pass the 190 mark at about 9300rpm
#71
I went with an M-Factory Final drive, at least pretty sure it is. James@synchrotech got it for me!
Here's a datalog from my 187mph pull. Hondata Traction control doing its thing pulling timing. Im pretty sure 4th gear was just a bump in the road.
Also, it was 80+ degrees out that day and IAT's went from 114 to 97 deg by the end of the run. Good FMIC FTW.
#72
Would have been nice to see you hit 190 with the same turbo / trans just picking away at the MPH. But kudos for change I suppose
#73
You're on e-85, correct? That would explain the lowering IAT's and ECT.
Ever monitor EGT's?
#74
where did you decide to locate your iat sensor?
thanks for sharing that datalog... very cool to see it working.
#75
I am not monitoring EGT's but our Evo that was there did, im sure his are similar to mine. 2.2L, 7175 turbo 50psi in 3/45th gear LOL.
