HELP 1999 accord bad multiplex I think!!!!
Old 04-20-2014, 07:23 AM
jalcocerjr's Avatar
Default HELP 1999 accord bad multiplex I think!!!!
Hey guys Thursday I received led bulbs I bought off ebay, I installed them fine then when I went to install the dash clock led bulb (key on lights on) it sparked and my dash warning indicator lights went out, windows don't roll down, blinkers dont blink, can't take it out of park only if I put a key in the shifter release hole and it shifts HARD, I went to the picknpull and "bought" 2 driver side multiplex same deal please help it's a 1999 accord lx f23
Old 04-20-2014, 07:35 AM
Lost Again's Avatar
Default Re: HELP 1999 accord bad multiplex I think!!!!
Stop, back up, calm down and let's think about this.
I'm going to guess you have a blown fuse, #9 drivers dash. The #9 it is tied to both the clock and the brake pedal.
EDIT: Sorry, was reading the wrong wire diagram......corrected.
Old 04-20-2014, 09:28 AM
jalcocerjr's Avatar
I'll check it out again, I may have over looked it all fuses looked good when I checked but I'll look again
Old 04-20-2014, 03:28 PM
MM Gruppe B
MAD_MIKE's Avatar
Fuses can 'look' good even if they are blown. Use a voltmeter to test, or replace with a same amp fuse, to verify the circuit is not blown.
Old 04-20-2014, 05:04 PM
jalcocerjr's Avatar
# 9 fuse it was it looked good but no continuity thanks again guys
Old 04-21-2014, 04:26 AM
Lost Again's Avatar
Good to hear
Scraper
07-12-2016 09:02 AM
FroMan
04-23-2012 04:20 PM
RobRussell
06-19-2009 10:06 PM
s2b EuroR
05-13-2008 12:01 PM
Quick Reply: HELP 1999 accord bad multiplex I think!!!!
