Got no vtec and rev limit at 7k...b18c1
Old 04-20-2014, 07:10 AM
Vtec_Dude's Avatar
Default Got no vtec and rev limit at 7k...b18c1
I got a 92 honda civic hatch with b18c1. So the issue is that I got no vtec and rev limit at 7k on a p72 ecu. Done all the troubleshooting fixed a lot of the wiring and check the vtec solenoid, does the click when I apply straight power from battery. Put in a new vtec oil pressure switch and cleaned out the housing that holds the two also. The only thing that I'm not too sure about is the IAT, the wires for them we're cut for some reason fixed that and it burned the original ecu that I had but it didn't burn the p72 ecu. I just got back into the game so can anybody help?
Old 04-20-2014, 08:01 AM
carlos8's Avatar
Default Re: Got no vtec and rev limit at 7k...b18c1
After change the ECU, do you connect the IAT?
Burning a ECU by plug the IAT is normally when mixed with purge valve plug.
Any CEL, Stock ECU or chipped?
Old 04-25-2014, 09:54 PM
Vtec_Dude's Avatar
I get a CEL only when I get on the gas and pass 4500 rpm. I got a virgin p72.
Old 04-28-2014, 06:18 AM
Recaro's Avatar
My guess is that it's the ECU, put it a p28 chipped and it should be good, but first and foremost id fix the CEL first.
Old 04-28-2014, 08:35 PM
Vtec_Dude's Avatar
I'm just gonna redo the whole wire harness as if I did the swap myself after I do a oil pressure test sometime soon. I might just find a reason for me to get to my goal of 10's sooner than I thought.
gorthjr
05-11-2010 08:55 PM
92EGMINIME
20
03-06-2009 07:14 AM
Acura_I-RS
10-30-2005 09:06 AM
USDMGD3!
06-15-2005 06:29 AM
Turboholic
08-25-2004 07:16 AM
Quick Reply: Got no vtec and rev limit at 7k...b18c1
