Any advantage in skinnie tire size
Is there any advantage in going with a 22" over a 24" skinnie, or vise versa? for example would a NA 280whp car see any difference in ET between these two sizes?
thanks
thanks
Re: Any advantage in skinnie tire size
More than likely equals out imo.. 24" weighs more but also has more grip, 22" weighs less but also has less grip. Its a matter of personal opinion.. I'd go 24s on the front and 22's on the rear.
Been there, done that with plenty of circle track cars.
Keeping the axle centerline the same in the front and raising axle c/l in the rear will move CG forward when everything else is constant. With only 2" difference it won't be very much but it will move CG forward.
You have make sure that the spring will actually transfer the weight a softer spring will compress. I did tgis using scales and pretty much toped out my rear coilovers and saw no difference in the front weight on the tires all it did was compress the rear. It doesnt squat as bad when i launch but with the correct spring rates you would have better success.
