O2 sensor
O2 sensor
Can someone please tell me if this is a normal reading or do I have to take action?
ECL P0420, I cleared it the took a voltage reading
I have attached a screen shot for your veiwing. Thank you in advanced
2k accord V6 3.0L
ok so I dont know how to upload the jpeg here are the numbers
o2 1x2 voltage reading is .5 to .8 when accelerating
o2 2x2 voltage reading has no data <<< im questioning this one
2k accord V6 3.0L
MM Gruppe B
Re: O2 sensor
Secondary O2 sensor should either hold a steady low voltage reading, or if the secondary combustion is not fully happening in the catalyst, the secondary O2 will follow the primary O2s voltage output.
Re: O2 sensor
Thank you, that kind of made sense to me. I will monitor the numbers while in cruising speed. So far so good, looks like it might have been a false/positive in the ECU
MM Gruppe B
Re: O2 sensor
P0420 is a code that takes a bit to set if the catalyst or secondary O2 are failing. If the catalyst is outright dead the code will come back fairly quickly.
