94 civic with b18a1 swap
Old 04-17-2014, 08:04 AM
leaeno21's Avatar
Default 94 civic with b18a1 swap
when i start my car and let idle for a couple min and
when i finally hit the gas to rev it up i lose power.
it doesn't turn off but the rpms drop and when i
let go of the gas my rpms go back up....
could somebody help me and let me know whats
going on with my car please
Old 04-17-2014, 08:19 AM
PHANTOM MENACE
24TEN's Avatar
Default Re: 94 civic with b18a1 swap
When you say you rev it up you lose power, do you mean you hit the gas and expect the RPMS to go up but it doesn't go up at all?
Old 04-17-2014, 08:24 AM
leaeno21's Avatar
yes...hit the gas and rpms drop instead of going up. when i let go of the gas it goes
back to idle at 1300-1500
Old 04-17-2014, 09:18 AM
JuggerNaut-CTR's Avatar
Give more info....
Mechanical timing correct?
Ignition timing correct?
Last tune-up?
Ecu?
Cel's?
iacv, and fitv clean and idle screw adjusted?
Old 04-17-2014, 01:54 PM
leaeno21's Avatar
Ecu is p28 got my original wire harness. .I tried timing my car.. lined the pulley up and cam gears up and started my car and that's when my car losses power when I hit the gas. Well the rpms drop when I hit the gas. But when I let the off on the gas my car idles just about normal. B18a1 setup in my 94 civic 4dr.
Old 04-17-2014, 01:58 PM
leaeno21's Avatar
Cel is on due to my o2 sensor is unplugged. That's the only code I know of I'm not too sure about if there is any other cel code
Old 04-17-2014, 02:00 PM
yippee-ki-yay
eHMxhACk's Avatar
Is the motor itself dropping RPMs or are you taking about the tachometer only?
eH.
Old 04-18-2014, 05:06 AM
leaeno21's Avatar
Motor loses power.... The motor like hesitate when I hit the gas.... She don't Rev up like she suppose to. .
Old 04-18-2014, 06:34 AM
I never narc'd on nobody!
NotARaCist's Avatar
Pull all of your CEL codes and post them. Once you've done that, reset your ECU and see what codes return. Diagnostics 101.
So you've done mechanical timing, but have you checked ignition timing?
Swooten0782
10-05-2017 05:47 PM
blue2006civic
Honda Civic (2006 - 2015)
06-17-2015 06:13 PM
kraemer
06-09-2010 11:20 AM
mongoliandonuts
09-22-2004 06:52 PM
pbizzlegsr
03-13-2004 01:04 AM
Quick Reply: 94 civic with b18a1 swap
