curb hit need help
Old 04-16-2014, 06:21 PM
Vladglad's Avatar
Icon2 curb hit need help
Hit a curb the other day trying to avoid a collision in the rain ended up sliding into
the curb and bent my rim.it was lumpy but i made it home. So then changed my
rim,and the rim in not centered correctly its pushed back more compared to the
drivers side. what may have i damaged ? by the looks it looks like the sway bar i
is bent. can this cause it to be pushed back more. any help with be greatfull
thnx
1997 ex cuope
Old 04-16-2014, 07:15 PM
slowDB7's Avatar
Default Re: curb hit need help
Some pictures will help us
Old 04-16-2014, 07:35 PM
B serious's Avatar
You probably bent your lower control arm, subframe, or knuckle.
Probably your lower control arm if your swaybar looks bent. Swaybars aren't load bearing parts. So you need to bend quite a few other things to bend a sway bar from a collision.
Old 04-16-2014, 08:29 PM
PrettyMuchBoned's Avatar
You probably bent your lower control arm[/quote]
Old 04-21-2014, 09:05 AM
Vladglad's Avatar
Here are some pics
Old 04-21-2014, 09:06 AM
Vladglad's Avatar
Old 04-21-2014, 09:07 AM
Vladglad's Avatar
Old 04-21-2014, 09:09 AM
Vladglad's Avatar
Old 04-21-2014, 10:15 AM
Take a picture parallel with the lower control arm's main piece, which connects to strut and spindle.
or check it yourself with a straight object..
you need a new swaybar for sure.
Old 04-21-2014, 10:28 AM
Originally Posted by PrettyMuchBoned
Your bushings may be bad too, but I can't tell.
can you jack up the front of the car and try to check everything with a ridged metal meter/yard stick? This would be a good way to check if your subframe is bent. You have to compare it to the car itself like the firewall or radiator support if that isn't bent.
if it seems tweaked whatsoever, I suggest getting one plus lower control arms, knuckles (spindle hub bearings), swaybar, new swaybar links (5$ each).
if your struts are bad/bent/old might as well try for those too. OEM struts are good, but they're leaking or clearly broken dont pay for em. Same goes for your rack if it leaks or feels mesed up.
these are the things most likely to bend hitting a curb, IMO. Yes, everything. It all absorbs the damage. Along with your tires and wheels..
if you get it pulled out ready for pick up it shouldn't cost more than 300$. Maybe 500$ with rack struts upper control arms + ball joints, but only if every thing is pristine condition no tears in bushings no leaky struts non rusty subframe/control arms etc.
Old 04-21-2014, 10:56 AM
TOP91's Avatar
My first guess would be the lower control. You may not really be able to tell untill you put it next to a new one and see how obvious it really is. Inspect along the frame and make sure its not bent, is your fender lined up fine? Does the gaps match the drivers side for the good and door? i would look at easy things like that first. Your sway bar is spring steel, they usually don't bend unless it has been heated first so if something is pulling it back then it should spring back into place. You can check the "dirt" lines around the sway bar bushings on both sides of the car. Inspect the subframe and its bolts to see if anything is bent or shifted. The upper arm should be fine because the strut tower will give a little bit. look at your rack and pinion and see if its shifted any.
If i was to look it over and not be able to tell whats bent or shifted i would get a new lower arm off ebay for cheap unless there is one at a junkyard near you. and compare the two to see if its bent. if not you can always send it back. Or install the new one and see if its fixed! and go from there. In my opinion the less money it takes to fix a car the better. You can always go back and change the bushings and sway bar links, but the main thing i would think is getting it back on the road.
Make sure you soak the bolts in pb blaster and be careful not to snap off the heads.
Also am i seeing this wrong?????
Old 04-21-2014, 01:46 PM
Vladglad's Avatar
okay so from all the info i will need a new sway bar ? and a new LCA? replace the bushings
Old 04-21-2014, 01:47 PM
Vladglad's Avatar
@TOP91 what are you seeing wrong ???
Old 04-21-2014, 03:37 PM
Vladglad's Avatar
And possibly buy another front subframe ?
Old 04-21-2014, 03:50 PM
slowDB7's Avatar
seems like your subframe is bent
Old 04-23-2014, 06:04 PM
Vladglad's Avatar
Here are some more pics and does any one know the part number of the LCA ?
Old 04-23-2014, 06:06 PM
Vladglad's Avatar
Old 04-23-2014, 08:07 PM
Why do you want a part number? They're aprox. 50$ from summit/rock auto. Pull em out and replace.
I just pulled out my subframe to replace em along with the entire front suspension.
paid 300$ for LCA, ball joints, UCA w/ ball joints, sway bar links, and I got a shim kit for the hell of it incase the alignment shop needs em. Advanced wanted 600$ but I had em price match rock auto.
I got a subframe from an Integra too, since a cap nut broke off of mine. Freakin 1 dumb nut cost me a 50$ subframe and 2 hrs labor (took me 3 1/2 the first time).
Rand The Man
07-07-2010 01:53 AM
lazyxmofo
08-13-2009 01:12 PM
dc2leftovers
07-24-2009 12:27 PM
chb93
02-28-2009 11:19 AM
si90rex
Welding / Fabrication
10
03-15-2008 06:06 PM
Quick Reply: curb hit need help
