Short Shifter
Short Shifter
Hey,
I own a honda civic coupe lsi 1995, and i wanted to install a short shift gearbox the problem is that i dont undestand anything of brand parts. Any advices?
PHANTOM MENACE
Re: Short Shifter
It's been years since I've had to remove mine but if I remember correctly all I did was remove shift **** so the shifter can fall through it's opening, two bolts underneath the car holding the shift linkage to the tunnel, and I believe two more hold the two linkages together, and last the bottom bolt holding the lower linkage to the shifter. That's not alot of disassembly in the grand scheme of things (unless you are running something that required a cable shifter be installed and didn't mention that in your first post).
dxhatch93
02-07-2006 05:19 PM
Irishweird00
08-12-2003 01:47 PM
