92 Gsr exhaust question
So I rrecently bought a 92 GSR shell and swapped my built LS into it. I have been doing a little searching for an exhaust system. I cant tell if I need a catack system specifically for a GSR or if it will still fit for an LS/GS/RS model.
Suggestions???
Suggestions???
Re: 92 Gsr exhaust question
well you need a exhaust for a 92 integra!. Now it will differ depending on what header your using cause of the different lengths they come in depending on what year motor its from. so if its a ls motor from the same body style year then a cat back for that 92 year LS is what you need if its a newer ls motor from say the 94 and up chances are the header is a bit longer and will need some fabrication at a muffler shop to extend the piping or you might get lucky and it will fit. Just get a cat back for the 92 integra it don't matter if its for a gsr gs or rs they will all fit basically the same. Either way you just might end up needing the piping extended or shortened depending on the header and if your using a cat or test pipe.
Awesome thank you so much for the reply I greatly appreciate it all I need to finish my build is my jrsc belt on backorder and some Na fuel fittings and the exhaust and time to start
