HELP radiator problem
I have a 95 prelude h23 that has been having some problems with the radiator. Scince i blew my headgasket i have replaced the following parts(headgasket , waterpump, timing belt, thermometer , radiator cap) and flushed both radiator and engine multiple times untill i got all the oil out of the radiator and all the water out of the engine but still my car overheats for no reason, i have been going crazy over this problem someone plz help
Re: HELP radiator problem
Make sure the thermostat is installed in the correct direction, and working properly. Make sure the system is fully and correctly bled of all air.
Also make sure that both lines to the radiator have fluid in them circulating. Also verify that your fans are turning on when they are suppose to. Your switch my have gone bad if the fans dont turn on.
Nocturnal
12-02-2005 08:20 PM
