Prelude with moments :/
Old 04-09-2014, 02:14 PM
Z99doc's Avatar
Default Prelude with moments :/
I have a 92 Honda prelude that starts on a regular basis and sometimes just doesn't start.... like the starter will keep going but no spark in the engine i'm guessing... then after you come back to it maybe 5 min later it starts..... i'm not understanding what the issue is. Please help
Old 04-09-2014, 05:00 PM
Sparksman's Avatar
Default Re: Prelude with moments :/
Air, Fuel, Compression, spark and timing is all it can be.
Check ignition timing, the TPS. Maybe bad starter, loose connection/ground, or dead battery.
Next I would try a compression leak down test if you havent fixed after checking all those.
Old 04-10-2014, 12:35 PM
Z99doc's Avatar
could water in the fuel cause this also and i just kinda realized it only does it on warmer days.... for instance this morning (it was cold outside) it started and ran just fine this afternoon (it was hot out) it was doing that thing again where it was trying to start but wouldnt.
Old 04-10-2014, 02:25 PM
Moderator
snobordboy's Avatar
I am not a betting man, but I have a nickel that says it is a main relay issue. Using Google or the search on here should find you some answers.
Old 04-10-2014, 02:48 PM
yohan's Avatar
main relay x2.
When you turn your key forward to ignition i (before cranking) you'll normally hear a "tick" come from under the dashboard, this is the main relay clicking on. If you don't hear that click, it's likely failed.
Old 04-22-2014, 04:43 PM
Z99doc's Avatar
It was the main relay Thanks guys
Old 04-28-2014, 06:26 PM
93_BB2_Prelude's Avatar
My 93 did the same thing and I couldn't figure out what it was could be the main relay. I ended up replacing the starter and it fixed the problem. But good luck on fixing your problem.
si_motor_spt
08-17-2022 10:52 AM
dcskater56
12-22-2009 06:46 PM
LSBeast
01-19-2008 07:41 AM
cindysi
10-11-2006 09:15 PM
outkast_teggy96
06-14-2006 03:29 PM
Quick Reply: Prelude with moments :/
