93 civic hb cx - Orientation of wheel bearing does it matter?
Old 04-09-2014, 10:41 AM
JohnnyEF's Avatar
Default 93 civic hb cx - Orientation of wheel bearing does it matter?
I Bought a new OEM NTN Honda wheel bearing and in the process of pressing the bearing into the front knuckle of a 93 civic hb cx. The wheel bearing that I removed from the knuckle looks identical in nature on both sides of the bearing.
The new wheel bearing I received has black plastic on one side of the bearing between the races, and the other side is majority all metal. Which side of the bearing should be facing which direction? Does it matter? Any input would be appreciated.
Old 04-09-2014, 10:51 AM
JohnnyEF's Avatar
Default Re: Orientation of wheel bearing does it matter?
Pics
Old 04-09-2014, 01:51 PM
JohnnyEF's Avatar
ttt
Old 04-09-2014, 02:39 PM
10cjennings's Avatar
In for answer too. I checked the FSM and it doesn't mention it in the wheel bearing replacement section.
Old 04-09-2014, 02:50 PM
JoeBlue's Avatar
No, orientation does not matter. They are not unidirectional bearings. They should only fit one way as well, so that makes it easy to figure out
Old 04-09-2014, 02:56 PM
GDD Member
slomofo's Avatar
The problem with that statement is that they can go on either way.Everything else is correct, it doesn't matter which side goes where.
Usually the only ones that matter are the type that come on Acura TLs which have a little magnet attached to them when you buy it. The magnet is there to indicate which side of the bearing has the trigger wheel for the ABS sensor.
Old 04-09-2014, 03:04 PM
So one side is different from the other for no particular reason?
Old 04-09-2014, 03:58 PM
Seagull Management
94EG8's Avatar
Default Re: 93 civic hb cx - Orientation of wheel bearing does it matter?
Metal side goes out. It really doesn't make a whole lot of difference, but the metal dust shield is more resistant to the elements.
Old 04-09-2014, 05:12 PM
JohnnyEF's Avatar
So you would face the metal side towards the lugnuts?
Old 04-10-2014, 02:02 AM
Seagull Management
94EG8's Avatar
Away from the lugnuts, the side facing the lugnuts is covered by the hub, the other side is a bit more open.
Old 04-10-2014, 09:08 AM
JohnnyEF's Avatar
Gotcha, thank you.
JohnnyEF
04-09-2014 10:16 AM
lv6l
12-18-2008 01:57 PM
techforay
Honda Civic (2001 - 2005)
10-26-2008 08:16 AM
ViZ
02-11-2005 07:52 PM
Quick Reply: 93 civic hb cx - Orientation of wheel bearing does it matter?
