Accord 1996 : PCV Hose
Hi,
I just broke my PCV Hose when replacing my PCV valve.
I just check online and just the hose cost 36$$$
http://www.hondapartsunlimited.com/h...acuum-7-3x3000
Where can I find and what king of hose can be used a cheaper solution to replace the PCV hose ??
Thanks
Thanks
MM Gruppe B
Re: Accord 1996 : PCV Hose
7.3mm hose x 3000mm. 'bulk'. That's 3Meters of 7.3 hose at Honda prices.
Go to your local parts shop and look for 7.3mm vacuum or fuel hose, if no metric sizes look for 9/32", you will need about a foot.
Should be a dollar out the door.
I ll check at the part store !
Thanks Mike
I installed it , well I will see it it handle the heat
Is that good ? I don't really known about the temperature it can handle.
Did you changed you hose too ? If yes what kind of hose did you use ?
MM Gruppe B
Wiper hose will probably not last long, but it is better than nothing in the interim.
Reinforced vacuum hose that is fuel resistant or fuel hose would be better.
Oil vapor and blowby are what will be in the crankcase and recirculated via the PCV system.
MM Gruppe B
Fuel vapor, as in blowby, will travel in the line. Anything that is not fuel rated will deteriorate from gasoline/gasoline vapors.
