'02 motor mounts (how to remove rear motor mount)
Old 04-05-2014, 03:48 PM
ConceptVBS's Avatar
Default '02 motor mounts (how to remove rear motor mount)
Got a '02 Civic.
In the process of removing left, right and front motor mount.
No idea on how to remove the rear motor mount.
Any ideas?
Old 04-07-2014, 07:30 AM
05civic's Avatar
Default Re: '02 motor mounts (how to remove rear motor mount)
You'll have to remove the 3 bolts that attach to the trans, and also the few that attach to the subframe. At least that's how I did mine
Old 04-11-2014, 07:42 PM
ConceptVBS's Avatar
How did you access the mount? From the engine bay? I just had my intake housing taken out but it seems like a really tight fit. Don't know what tools to use to break the nut either. Care to share how you did yours? Much appreciated.
Old 04-15-2014, 06:18 PM
WuBangerMac's Avatar
I just did mine, you have jack up the car, climb under it and get at it from underneith. it was a pain getting eveything out and back in. you need to seperate the mount from the bracket to get it out, then bolt the trans bracket back on and slide the mont back into place. it took a while to figure everything out.
Old 04-17-2014, 06:14 AM
eg-owns you's Avatar
I just did my mount inserts last weekend.
1. jack up car high enough so you can get some leverage on the wrenches
2. unbolt the T mount there are 4 bolts all together
3. there are 3 bolts holding the actual mount to the sub frame
4. remove the sway bar for easier accesses
5. the hardest bolt to get out will be the one right above the exhaust that was the last bolt i took out and the first one to put back because i could not get the wrench out of that tight space lol
AdamsAutoAdvice
01-20-2020 07:19 AM
HypL
08-04-2012 08:26 PM
asianman139608
07-02-2010 05:50 PM
1badcrx
08-04-2009 03:03 PM
NA-GSR
09-20-2002 07:38 AM
Quick Reply: '02 motor mounts (how to remove rear motor mount)
