High compression B20?
Old 04-03-2014, 04:17 PM
ThatSlowKid's Avatar
Default High compression B20?
Ok well I have recently purchased a B20 from Pacific Import. The motor came out of a 2001 CRV it has the P8R head which I know is rare, but I don't know if my motor is high compression or not. If it doesn't have a knock sensor that means its automatically a low compression motor?
Old 04-03-2014, 05:14 PM
darnizzle8805's Avatar
Default Re: High compression B20?
I'll buy the head if you are interested in selling it.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/b20-non-vtec-faq-guide-including-p8r-head-information-1467903/
Old 04-03-2014, 07:12 PM
Fish Twig
tony_2018's Avatar
So whats your real question since you already answered your question?
Old 04-03-2014, 07:14 PM
I was wondering if my motor was high or low compression but now I know that it's a low compression since it doesn't have a knock sensor. Damn that sucks
Old 04-03-2014, 11:23 PM
Retired Moderator
EsotericImage's Avatar
All B20's arent a true high compression engine. even the 9.6:1 isnt considered a high compression. its a little on the low side.
Ive had a B20 with PHK pistons and a P8R head, so it just means if you really want to know, then youll have to pull the head off to see what you have.
Nut a decent set of cams and a tune and youll have a nice little street engine
Old 04-04-2014, 01:09 AM
Thanks for the info. Will do on the cams but it can wait. Still deciding on which transmission would be best on it. I have a B16 but I think a GSR would be better
Old 04-04-2014, 02:51 AM
PhilStubbs's Avatar
The crv uses cables to shift, so without a good bit of work, you aren't using either of those
Old 04-04-2014, 04:22 PM
So why did my friends GSR tranny bolt on his B20 with no problems?
Old 04-04-2014, 05:21 PM
blackeg's Avatar
they bolt together but you cant use a gsr trans in a crv or vice versa because of the shifter linkage.
cant you just check the stamp on the bottom of the block or oil pan to see if its p3f or phk? do some p3f blocks come with the phk pistons inside?
also, i was under the impression that the p8r only came on the low compression 8.8-9.2 motors not the high compression 9.6 motor. learn something new every day
Old 04-04-2014, 11:11 PM
Retired Moderator
Yea, the bottom of the block doesnt show the real pistons. I thot the same thing. I didnt know until after I pulld the head and saw it for myself.
even still, the 9.2 and 9.6 isnt much of a margin. the PHK piistons added to the the 47cc chambers of the P8R will bring it around 9.2.
the 8.8 is just a pain in the *** unless you want to build it past 11:1 and get some performance out of it.
EDIT: there was a 2 layer HG that would bring the P8R equipped B20 to 9.6, but those HG's are hard to find. I thought I bought a 2 layer with OEM part number, and it turned out to be a 3 layer. So the real 2 layer HGs are non existent except in japan.
Old 04-05-2014, 01:37 PM
PhilStubbs's Avatar
What I said had nothing to do with bolting the engine and tranny together. It has everything to do with shifting it in the crv
Old 04-05-2014, 06:27 PM
Fish Twig
tony_2018's Avatar
What car did that engine/tranny go in? That should be your answer why it fit. If it were possible to fit a hydraulic tranny to a CRV everybody would've been doin it by now
Old 04-05-2014, 06:29 PM
Fish Twig
tony_2018's Avatar
We're comparing b20's here, if it were comparing a b20 to a b18c of course thats no contest.
Old 04-07-2014, 07:48 PM
Retired Moderator
well heres a comparison link
https://honda-tech.com/forums/showth...1#post49635561
Old 04-10-2014, 09:27 PM
Well he put it in an Integra and I'm putting it in a hatch. So yeah it would fit
Old 04-11-2014, 04:21 AM
PhilStubbs's Avatar
Then why are you in the crv forum? If you just want b20 there are plenty of places to get that.
Timothy Yhtomit
02-07-2018 06:42 PM
804tuned
Engine Management and Tuning
06-18-2009 10:57 AM
felipe69
04-01-2009 06:10 PM
thabao
01-20-2009 04:01 PM
Mr.EGo
07-09-2007 10:09 PM
Quick Reply: High compression B20?
