fuel pump / no voltage?
I do not have 12V at the fuel pump connector. My fuel main relay is good, my fuel pump is good. (tested it directly with 12V)
So my problem is from the fuel main relay to the fuel pump connector.
Has anyone have had a short from the front compartment (fuel main relay) to the rear (fuel pump) connector wiring??
These tests are with the ignition key on.
There is a "box" looking grey connector at the fuel pump that has only 6V power with the ignition key on.
My 99 Civic won't start anymore. Its worked yesterday, came out in the morning to go to work, turns over, but won't start. I don't have fuel.
I will be checking if there is any continuity from the main fuel relay connector pin terminals 5 & 7 to the 2 terminals on the fuel pump connector. I just don't have a long enough jumper wire to do this. I'm going to buy one.
Any ideas??
Any ideas??
