Type s swap in base rsx
So I picked up a smashed type s from nj the other day an I just took the car apart today. The car came with lost of goodies all around. That being said, I want to take the s swap an drop it in my rsx (tranny an all) I looked some stuff up an all ppl wore talking about was the ecu. I took the ecu from the type s so I should be good. I would like to know if there is anything else I should be looking out for before I start this project. I'm only putting the swap in the car all the other goodies are up for graves.
Re: Type s swap in base rsx
just taking the ECU does you no good, you need to swap everything like the keys, ignition and immobilizer. You will need an immobilizer bypass or kpro. I recommend kpro if you plan on modifying the car in the future. Either way you need to get around the immobilizer.
Accord k24a4
11-29-2010 05:58 AM
