93 Accord Fan stays on after shutting off.
Old 03-20-2014, 06:16 AM
93Accordman's Avatar
Default 93 Accord Fan stays on after shutting off.
Fan stays on for 10 or more mins after i shut the car off. Any help?
Old 03-20-2014, 07:22 AM
fcm
Old Fart
fcm's Avatar
Default Re: 93 Accord Fan stays on after shutting off.
ECT B switch is turning on rad fan control module because engine is hot.
ECT B switch is defective.
Rad fan timer module is defective.
Unplug the ECT B switch and see what happens, right side of engine in coolant outlet, 2 wire plug, [black and white/green leads]. 94
Old 03-20-2014, 09:03 AM
Thanks I will try that. It wont kill my battery right?
Old 03-20-2014, 01:30 PM
fcm
Old Fart
fcm's Avatar
What, unplugging the ECT B switch or having the rad fan run after engine is turned off?
Unplugging ECT B switch, no.
Having rad fan run after engine is turned off, maybe, but only if it keeps running for more then that 10min. and then it depends on how long it runs.
It is "normal" for the rad fan to run after engine is turned off, there should be a label "Caution Rad Fan Can Turn On At Any time" or something like it in the engine bay at rad fan shroud.
If the rad fan still turns on after unplugging the switch, the problem is the timer unit, again, it is normal for it to turn on for a little bit if engine is hot. 94
Old 03-21-2014, 04:53 AM
Thanks again buddy.
Old 03-21-2014, 05:25 AM
holmesnmanny's Avatar
the fan timer is designed never to run for longer than 10 minutes so if it is that means its bad
davexnet
04-09-2019 01:49 PM
maglites94
03-10-2012 07:40 PM
95WhiteTeg
09-02-2011 05:55 PM
GSE980
05-15-2007 09:00 PM
fathergoose
01-31-2005 02:12 PM
Quick Reply: 93 Accord Fan stays on after shutting off.
