Can't Figure Out Why Car Keeps Dying
Old 03-15-2014, 12:19 PM
Bleakened's Avatar
Icon2 Can't Figure Out Why Car Keeps Dying
A few days ago my ek hatch wouldn't start. It started to crank but all the lights dimmed down to almost nothing and it wouldnt crank so I got stuck.
Got my battery (somewhat) tested. It had 0% charge and my mechanic said it probably had bad cells so I replaced it.
1 day later, it did it again and the battery is dead again.
A few things to know:
1. I tested the alternator myself by pulling the battery out while it was running and it didn't die. (I know this doesn't tell you a lot but it shows me it works to some capacity atleast)
2. Prior to the 2nd battery dying, my battery light on the cluster would come on until I revved the engine and would go back off.
3. Starter is starting to die (grinds, sticks once in a while)
4. It is able to be jumped.
TL;DR - Battery dies, dying starter and car won't charge.
So anyone have any idea of why it keeps dying? I think it's the alternator not keeping up but want more opinions before I throw parts at it.
Old 03-15-2014, 12:53 PM
Bleakened's Avatar
Default Re: Can't Figure Out Why Car Keeps Dying
Update: it tested 12v flat when car was off and after I tried (and failed) to start it, it read 11.75.
Old 03-15-2014, 07:37 PM
Bleakened's Avatar
Can anyone say if they think it's the alternator or something else?
Old 03-16-2014, 01:28 AM
Fish Twig
tony_2018's Avatar
Check grounds, check alternator fuse? Any audio systems, anything installed lately that requires a 12v or removed?
Old 03-16-2014, 04:07 AM
carlos8's Avatar
The easiest way to check your charge system is with a voltmeter, set it to 20v and check the battery with the engine off should have 12 to 12.6v then whit the engine running check again you should see 14.0v - 14.6v.
Check the alternator belt adjustment. Any CEL? A bad ELD can do this.
Old 04-24-2015, 01:37 PM
vfeezy's Avatar
start your car and while the motor running (at Idle) turn your a/c on high and you headlights on high beam. Than check the voltage at the battery. You should have about 13.8 volts at the battery. This normally means that you have a weak alternator or your voltage regulator is bad.
Johnoolo
09-16-2013 05:15 AM
schueytenten
10-23-2010 03:45 AM
neremixed
12-18-2008 03:28 PM
s2kkk
20
04-01-2004 12:54 PM
tchet
10
04-17-2003 10:27 AM
Quick Reply: Can't Figure Out Why Car Keeps Dying
