Oil pump replacement
I have a 94 Integra ls vtec, im going to be swapping out the old oil pump... I have never done this before, or even replaced a timing belt. So this will be my first time. I bought the obd2 oil pump as everyone says to do (15100-p72-a01) that is oem. The pump came with the seal in middle but did not come with the o ring or the gasket that connects to the pick up tube. So I will be getting them soon. Also I still need the oil pan gasket. I got a new water pump with the car so I will be putting that on as well while I have it all off... It has a new gates timing belt on it that was done right before I bought the car so I will not be changing the timing belt, just the water and oil pumps. From my understanding these are the steps I should do. Drain the oil, remove driver side wheel, remove driver side motor mount to allow that side of motor to drop, remove accessory belts (power steering and alternator, I don't have a/c), remove valve cover, remove oil pan and pickup tube, set crankshaft to tdc, remove crank pulley, remove timing belt covers, loosen timing belt tensioner, remove timing belt, remove water pump and replace, remove oil pump and replace, then put it all back together, making sure that the cam gears are at tdc as well as the crank when putting the belt back on? If im missing anything or have any suggestions that will make it easier let me know please. Thanks for any help in advanced.
Re: Oil pump replacement
Thanks... I guess I wasn't typing in the right stuff to find that... haha... so I can just follow that and instead of just pulling off the water pump I pull the oil pump as well? that's the only difference?
snatch
12
03-15-2005 10:12 AM
