96 civic lx won't start after it rains
My 96 civic lx will not start after it rains or after I go through a car wash. When I go to restart it everything is reset and the ecu is clicking. Also when it does start it will develop a low idle about 500 Rpms Is this moisture in the ecu? And it is a good idea to replace it? Thanks
Re: 96 civic lx won't start after it rains
Have not checked for moisture. The radio resets. And the clicking is coming right around the ecu/glovebox area. The fuel pump primes but all the power is very faint meaning low. Lights are dim blower motor barely works ect...
Does the starter crank the engine fine when the problem occurs?
Have you cleaned and tightened the G1 battery ground connection to the chassis, the G3 transmission ground at the chassis and transmission, and the G101 ground on the thermostat housing?
Have you checked whether the 7.5A hood Back Up fuse is blown?
Does the problem only happen after getting wet? Is it fine during dry circumstances or does the low idle occur all the time?
It is only when it gets wet. I got a car wash Saturday it was fine all day and Sunday. But this morning it occurs. Main relays keeps clicking continuously with key in on position. Also it's all I have a dead battery dash lights are dim. Headlights don't work. It's really weird
