Which oil pan gasket can I use?
Old 02-08-2014, 12:12 PM
datdurtyboi's Avatar
Default Which oil pan gasket can I use?
I have a 2000 civic ex and I have an oil leak by the oil pan. Now my question is when I Google "oil pan gasket" I get 2 different pictures. One of a flat gasket with holes for the screw and a tube like gasket with no holes. Which one do I use? I'm stuck because advance auto parts sold me the tube like gasket and they swear up and down that it right but I have a feeling it's not. I don't know how to install the tube like gasket if they're right. Thanks for the help.
Old 02-08-2014, 12:24 PM
B_Swapped93's Avatar
Default Re: Which oil pan gasket can I use?
I got an OEM one and it had the holes I'd trust that before the non hole'd one, nothing wrong with felpro tho I've used their stuff on my car.
Old 02-08-2014, 12:36 PM
In a Junkyard near you.
Ross 2.0's Avatar
Look at your oil pan, if it's clean aluminum you need the tube style. If it's painted black you need the flat one with holes. I would also only get it from Honda or World Pac.
Old 02-08-2014, 12:40 PM
But have you or know anyone that has used the tube like one before?
Old 02-08-2014, 12:41 PM
I haven't even tried replacing it yet because I don't want to do all the work for nothing.
Old 02-08-2014, 12:42 PM
Ross 2.0's Avatar
Just stick your head under the car and see what you have. You don't need to pull it off first.
Old 02-08-2014, 12:46 PM
Ross 2.0's Avatar
This takes the tube gasket
This takes the flat gasket
Old 02-08-2014, 12:51 PM
Ross I appreciate the info. I'll check right now brb
Old 02-08-2014, 02:38 PM
I have the tube gasket pan. I'll start doing it tomorrow thanks
boosted k20
02-10-2013 09:43 AM
j4s0n1337
11-24-2011 08:31 PM
miro_gt
06-24-2007 08:02 AM
4DRmafia
02-06-2007 12:04 AM
teler86
14
05-18-2006 05:18 AM
Quick Reply: Which oil pan gasket can I use?
