Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
GAIN 10-15% POWER TO THE GROUND - Guaranteed!
Old 01-27-2014, 05:24 AM
MFactory's Avatar
Icon7 GAIN 10-15% POWER TO THE GROUND - Guaranteed!
Hello Honda-Tech,
- Have you just spent, or are contemplating spending, a small fortune on engine upgrades?
Imagine this; you've just spent several thousand dollars to squeeze that last ounce of horsepower from your high-revving B-Series motor, only to be overtaken on the on-ramp by that base-model Civic DX? How embarrassing! (You're just glad your other half isn't sitting in the passenger seat)
So what went wrong? It's not driver skill (of course :p). More than likely, that puny little D-Series has what is known as, in engineering terms, a significant Mechanical advantage. In layman's terms? A transmission modified with aftermarket gears
- Don't want this to happen to you? If the answer is YES, MFactory Competition Products is the answer to your prayers!
Final Drive Gears
Description: By changing your final gear ratios, you can experience a dramatic increase in acceleration, giving you on average, a 10-15% increase in torque throughout the entire rev-range over the OEM Final Drive. CLICK HERE to see how much power you could gain!
Suitable for: Street Cars, Road/Race
Power Rating: ~300whp
Warranty: 1 Year Manufacturers Warranty against defects upon Receipt & Professional Installation
Why MFactory?: Our Final Drive Gears have been proven to be Stronger, Lighter and better performing than our competition
Feel the Torque™ Guarantee: An industry first! We stand by the quality of our products so much and, fully believe that you, our valued customer, will be fully satisfied with your Final Drive Gear that if, for whatever reason, you are not happy with your purchase, you may return the product to us for a full refund (excluding shipping costs) within 30 days of the purchase date!
Fitment Notes:
- Honda B16A2 Fitments: Will not fit models equipped with Factory LSD
- Honda Cable Fitments: Will not fit models equipped with Factory LSD. 92-93 YS1 transmissions should use B16A2 fitments
- Honda '98 Spec Fitments: Designed for the '98 Spec Integra Type-R with Factory 4.785 Final Drive
- Honda H22A Fitments: Will not fit ATTS-equipped transmissions. Fitment is suitable for Euro-R/Accord Type-R
Fitments:
B16A Cable (Non-oem LSD) - 4.928
B16A2 Hydro (Non-oem LSD) - 3.471*, 4.0*, 4.267, 4.533*, 4.600*, 4.71*, 4.923*, 5.167*
B16B/18C - 4.0*, 4.267, 4.71*, 4.923*, 5.167*
B18C JDM '98 Spec - 4.0*, 4.267, 4.71*, 4.923*, 5.167*
D15/16 - 4.5, 4.7, 4.9
H22A/F20B - 4.64, 5.15
L15 FIT (GD3 & GE8) - 4.47, 4.687
K20/24 - 5.08, 5.417*, 5.84, 6.33
S2000 - 3.90, 4.40, 4.57
R18A - 4.687, 4.928
CR-Z - 4.687, 4.928
*: Offering a revised design over our previous generation Final Drive Gears. Forged from stronger steel with a 50% larger tooth profile yet almost 1kg lighter!
Price:
B-Series / H-Series / FIT / S2000 / R18A / CR-Z - $599.95 inc FREE Shipping within Mainland US
B-Series 5.167 - $609.95 inc FREE Shipping within Mainland US
K-Series / H-Series 5.15 - $749.95 inc FREE Shipping within Mainland US
D-Series - $584.95 inc FREE Shipping within Mainland US
Package Deal 1*: Get 6L of Torco MTF for only $37 or 6L of Torco RTF for only $78.10 when ordered at the same time. That's a 35% Saving! Mainland US Only. $18.95 shipping applies
Package Deal 2*: Get an additional 10% discount off our Carbon-Composite Synchros, Synchro/Slider Kits and Master Rebuild Kits when ordered at the same time
Free Rebuild Service: Order our Package Deal 2 and we will rebuild your gear stacks for you Free-Of-Charge. No more worries about setting tolerances or rebuilding your gears stacks incorrectly; just plug-n-play. Mainland US Only. $22 shipping applies
* Package Deals can be combined
Close Ratio Gears - Synchronous Engagement
Description: We could talk about the benefits of gearing till we're blue in the face, so to keep this simple, please CLICK HERE to find out WHY you NEED to modify your transmission!
Power Rating: ~350whp
Why MFactory?: Our Close Ratio Gears have been proven to be Stronger, Lighter and better performing than our competition
Fitments:
Honda B16A/16B/18C (Semi-Helical Tooth Profile):
1st - 3.070
2nd - Re-use OEM 2nd gear
3rd - 1.625, 1.652 or 1.695
4th - 1.296 or 1.384 (Slight modification may be required to transmission casing when installing 1.384)
5th - 1.000, 1.033, 1.130 or 1.210 (Slight modification may be required to transmission casing when installing 1.130 and 1.210)
Honda B16A/16B/18C (Straight-Cut Tooth Profile):
1st - 3.070 (Semi-Helical)
3rd - 1.636, 1.670 or 1.704
4th - 1.313, 1.355 or 1.387 (Slight modification may be required to transmission casing when installing 1.355 and 1.387)
5th - 1.028, 1.118 or 1.210 (Slight modification may be required to transmission casing when installing 1.118 and 1.210)
Honda H22A (Semi-Helical Tooth Profile):
1st - Re-use OEM 1st Gear
5th - Re-use OEM 5th Gear
Honda H22A (Straight-Cut Tooth Profile):
Honda K20A (includes New Mainshaft):
1st - 2.313
2nd - 1.650
3rd - 1.304
4th - 1.080
5th - 0.958
6th - 0.851
CLEARANCE SALE: To make way for our new cutting-edge technology gear sets, we have all of our old B-Series, K-Series & H-Series fitments on clearance sale!
Price:
B-Series 1st Gear - $264.95 inc FREE Shipping within Mainland US
B-Series & H-Series Individual Gears (3rd, 4th or 5th) - $214.95 + $14 Shipping within Mainland US
K-Series 1st-4th - $1160 + $30 Shipping within Mainland US
K-Series 1st-6th - $1395 + $38 Shipping within Mainland US
Honda D15/16:
1st - 3.083 (Fits Cable & Hydro)
3rd - 1.565
4th - 1.250 (Re-use OEM 3rd Gear)
5th - 1.000
Price:
1st - $264.95 inc FREE Shipping within Mainland US
Choice of 3rd or 5th - $369.95 inc FREE Shipping within Mainland US
3rd/5th - $649.95 inc FREE Shipping within Mainland US
Close Ratio Gears - Synchronous Engagement (2013+ Range)
Description: Our all-new Close Ratio Gear Sets for 2013+, through the use of 21st Century R&D procedures and manufacturing techniques, we are proud to offer the most technologically advanced Close Ratio Gear Sets on the market today. All of our gears (including B-Series & H-Series) utilize dual-cone synchro technology for smooth and precise shifting.
Power Rating: ~500whp
Honda K20A:
1st - 3.130 (Can be used with the OEM Mainshaft. This longer 1st gear is suitable for those that require extra traction off the line, and is especially useful for those running a higher-ratio final drive. Can be purchased standalone. Does not require the use of our full gear set)
2nd - 2.167 (includes new Mainshaft. Can be used with OEM 1st Gear. Does not require the use of our full gear set). The solution to the weak oem K20 2nd Gear
3rd - 1.647
4th - 1.286
5th - 1.043
6th - 0.851 or 0.923
Price:
1st Gear - $369.95 inc FREE Shipping within Mainland US
2nd Gear - $1299.95 inc FREE Shipping within Mainland US
1st & 2nd - $1599.95 inc FREE Shipping within Mainland US
3rd-5th - $1299.95 inc FREE Shipping within Mainland US
3rd-6th - $1499.95 inc FREE Shipping within Mainland US
1st-5th - $2799.95 inc FREE Shipping within Mainland US
1st-6th - $2999.95 inc FREE Shipping within Mainland US
1st - 3.070
3rd - 1.636, 1.667 or 1.700 (Carbon-Composite Dual-Cone synchro included)
4th - 1.310, 1.357 or 1.410 (Carbon-Composite Dual-Cone synchro included. Slight modification may be required to transmission casing when installing 1.357 and 1.410)
5th - 1.054, 1.129 or 1.207 (Carbon-Composite Single-Cone synchro included. Slight modification may be required to transmission casing when installing 1.129 and 1.207)
1st - Re-use OEM 1st gear
5th - Re-use OEM 5th gear
Price:
B-Series 1st - $264.95 inc FREE Shipping within Mainland US
B-Series & H-Series Individual Gears (3rd, 4th or 5th) - $399.95 inc FREE Shipping within Mainland US
B-Series & H-Series Choice of 3rd and 4th - $729.95 inc FREE Shipping within Mainland US
B-Series Choice of 3rd, 4th and 5th - $899.95 inc FREE Shipping within Mainland US
Already have aftermarket gears in your transmission? Or even some that failed on you and is now just an expensive paper-weight?:
Depending on the type/brand, you may be eligible for the MFactory Refugee Program, a unique service which allows you to trade-in your old/damaged product for a brand-new MFactory equivalent at significant discount. Now you no longer need to have those expensive paper-weights taking up precious storage space! For more details, please CLICK HERE
For further information, please CLICK HERE to Contact Us, or send us a PM
<---------- IMPORTANT NOTICE ---------->
We have recently become aware of cheap and inferior "copies" of our Final Drives & Close Ratio Gear Sets, including our own custom ratios, being made available on the market. These DO NOT go through the same forging and heat treatment processes and will compromise your safety if installed on your vehicle. STAY SAFE and only purchase your Final Drives & Close Ratio Gears Sets from an Authorized MFactory Dealer
About MFactory
Established in 2004, MFactory Competition Products has since grown to become one of the Leading Global Manufacturers of high performance off-the-shelf aftermarket transmission components, with our large range of Forged Final Drive Gears, LSD's and Close Ratio Gears offering enthusiasts undeniably THE most cost-effective method of performance improvement, far surpassing that of conventional engine tuning.
Being a specialist in this industry requires focused knowledge that can only be gained through years of first-hand testing and tuning experience. Challenging the old adage that 'there is no replacement for displacement', MFactory Competition Products have become a prominent figure in the highest levels of Motorsport, with class-leading recognition the world over in Circuit Racing, Drag Racing and Rally.
Every product within the MFactory catalog is designed in-house in the USA and manufactured in-house to our own specifications at both our US R&D Facility and our multi-million dollar, state-of-the-art, ISO Regulated Taiwan factory, before being tested & developed in the real-world on state-of-the-art race vehicles from North America, Europe and Asia-Pacific. Our products are designed from the beginning to surpass the competition. Why choose MFactory? Here's why:
Official OEM to Honda of America's Motorsports Divisions
World's Largest Manufacturer of Forged Performance Transmission Components for Japanese and European Automobiles
North America's Largest Manufacturer of Limited Slip Differentials for Japanese and European Automobiles
North America's Largest Honda/Acura Performance Transmission Specialist
The World's Only Performance Transmission Manufacturer to offer a 30 Day Money Back Guarantee!
The World's Only Performance Transmission Manufacturer to offer a Discounted Trade-in for a Competitors Product; even if it's damaged!
Want more Information? To view our complete company profile and manufacturing processes, please CLICK HERE to visit our website
MFactory is offline
Old 01-29-2014, 08:21 PM
MFactory's Avatar
Default Re: GAIN 10-15% POWER TO THE GROUND - Guaranteed!
Keep the orders coming
MFactory is offline
Old 01-30-2014, 08:26 AM
MFactory's Avatar
If you have any questions, please feel free to send me a PM.
To order online, please click here: www.teamMFactory.com
MFactory is offline
Old 02-03-2014, 08:28 AM
MFactory's Avatar
The Worlds #1 Forged Gearsets & Final Drives for Honda :D
MFactory is offline
Old 02-03-2014, 08:31 PM
MFactory's Avatar
MFactory is offline
Old 02-04-2014, 08:57 PM
MFactory's Avatar
MFactory is offline
Old 02-07-2014, 10:03 AM
MFactory's Avatar
Contact us for our Hero Discount (Emergency Services, Military)!
MFactory is offline
Old 02-13-2014, 09:20 AM
MFactory's Avatar
All orders shipped out
MFactory is offline
Old 02-15-2014, 08:48 AM
MFactory's Avatar
MFactory is offline
Old 03-01-2014, 10:09 AM
MFactory's Avatar
All PM's replied
MFactory is offline
Old 03-04-2014, 09:53 AM
MFactory's Avatar
MFactory is offline
Old 03-05-2014, 09:36 AM
MFactory's Avatar
Everything in stock and ready to ship
MFactory is offline
Old 06-21-2014, 09:04 AM
MFactory's Avatar
MFactory is offline
Old 07-14-2014, 12:59 PM
MFactory's Avatar
All PM's replied
MFactory is offline
Old 07-27-2014, 10:14 PM
UncleD's Avatar
One of my favorite upgrades I have ever done. Don't underestimate this product people!!
UncleD is offline
Old 08-13-2014, 08:33 AM
MFactory's Avatar
MFactory is offline
Old 08-15-2014, 05:03 AM
MFactory's Avatar
MFactory is offline
Old 08-21-2014, 09:59 AM
MFactory's Avatar
All PM's replied
MFactory is offline
Old 08-28-2014, 01:22 PM
MFactory's Avatar
MFactory is offline
Old 09-02-2014, 10:32 AM
MFactory's Avatar
MFactory is offline
MADBADGER
Honda S2000
55
02-20-2015 03:25 PM
KENetics1
Transmission & Drivetrain
06-23-2014 11:25 AM
acura_b18c1
07-21-2012 08:58 AM
itr_18
09-22-2006 12:43 AM
Suck my DX
05-27-2005 06:14 PM
Quick Reply: GAIN 10-15% POWER TO THE GROUND - Guaranteed!
