2006 civic EX coupe, fail...
Old 01-18-2014, 06:32 PM
otherink's Avatar
Default 2006 civic EX coupe, fail...
Hello, I am new to the forums.
I got a major issue that is wrecking my brain right now, wondering if you can help me???
Is there something electrical responsible for EGR SYSTEMS and EVAPORATIVE SYSTEM??
Is there something I can do at home instead of taking it to the dealer?
Would disconnecting the battery AGAIN fix the issue???
I have all ready driven more than 70 miles after leaving the battery connected since Thursday afternoon.
My 2006 civic EX coupe with between 88k to 89k miles failed state inspection for a NOT READY status on EGR SYSTEMS and EVAPORATIVE SYSTEM.
When I put the ignition to start II, the OIL,BATTERY, AND ENGINE LIGHTS ALL GO ON. After 21 seconds the OIL AND BATTERY LIGHTS remain on but the ENGINE LIGHT blinks on/off 5 times and then turns off while only the OIL and BATTERY remain lit.
I disconnected the battery from the neg and pos connections numerous times last year 2013 some instances disconnecting it entirely for well over a month.
Now I left It connected since Thursday afternoon, drove more than 70 miles, and followed what was in the manual, although the part about driving 55 and leaving my foot off the gas for 90 seconds was hard to follow because I would decelerate too often and people would end up tailing me.
what do I do??? Is this a FUSE, ELECTRICAL, OR PHYSICAL problem?
Old 01-19-2014, 12:44 AM
holmesnmanny's Avatar
Default Re: 2006 civic EX coupe, fail...
It sounds like you got some check engine codes. Pull them. Fix the issues.
Then you have to drive a few times to ready the system.
Also, on obd2 systems you have to have the code cleared. You can't just disconnect the battery.
Old 01-19-2014, 06:40 AM
otherink's Avatar
how do I clear the codes on the OBD2 system? Is that something I can do myself?
Old 01-19-2014, 06:44 AM
otherink's Avatar
I should also note that at the DMV the printout listed that there were 0 codes and that there were another set of codes that came in as N/A.
Old 01-19-2014, 07:21 AM
otherink's Avatar
Is there anything physical that I can inspect to check that there is or isn't anything wrong? I just talked to someone from Autozone and they suggested that there isn't anything they can do. Pulling codes wouldn't make a difference. He recommended what everyone else does and just drive the car around (drive cycles).
Old 01-19-2014, 08:58 AM
turbonetics3597's Avatar
yes you can clear the code by disconnecting the battery
Old 01-19-2014, 09:02 AM
Originally Posted by otherink
Is there anything physical I can inspect to check that there is or isn't anything wrong? I just talked to someone from Autozone and they suggested that there isn't anything they can do. Pulling codes wouldn't make a difference. He recommended what everyone else does and just drive the car around (drive cycles).
if there are no codes present drive the crap out of the car and if u have an android phone you can get an elm 327 and the app torque and check to see when the monitor readys up on some vehicles it can up to 6 hours of driving best option freeways and large hills to pull
Old 01-19-2014, 11:20 AM
otherink's Avatar
Auto zone suggests pulling codes won't make a difference and the drive cycles matter. I have to keep driving then.
otherink
Honda Civic (2006 - 2015)
11
01-19-2014 04:31 PM
EgCouped15b
12
08-13-2013 05:53 PM
pellet36
09-01-2008 10:32 PM
MaZeRsX
10-31-2007 10:28 AM
blucivicracer
Honda Civic (2001 - 2005)
05-27-2007 08:36 AM
Quick Reply: 2006 civic EX coupe, fail...
