oil pressure light comes on
Old 01-09-2014, 07:16 PM
J.R
J.R's Avatar
Default oil pressure light comes on
hi, I have a 99 prelude SH, and the oil light comes on when it's warm and only when it's idling.
My friend a mechanic couldn't find where the sending unit is. Where is it located?
Old 01-09-2014, 07:19 PM
integra_101's Avatar
Default Re: oil pressure light comes on
under the oil filter.
Old 01-09-2014, 07:38 PM
preludeNApower's Avatar
Oil pressure will drop when warm... Pump may be failing, or loose clearances all over. Put thicker oil in and see if it changes. FYI that is not a fix
Old 01-09-2014, 08:39 PM
J.R
J.R's Avatar
He checked near the oil filter and couldn't find it, but he will look again. I have the SH model, could it be at a different place on the SH?
As far as the oil pump goes, I cannot find one. Are any available somewhere and are they something that can be replaced?
Old 01-10-2014, 12:50 AM
holmesnmanny's Avatar
on any vehicle it's going to be below the oil filter
it's not easy at all to replace an oil pump especially if you're not mechanically inclined(they have to remove the oil pan in addition to the timing belts) ... if someone is going to replace that it would be best to do a full timing belt side overhaul(seals and possibly belts, possibly water pump) ... this assumes nothing has been replaced there before(outside of the belts of course)
first thing's first...check for a dented oil pan...this is the first thing you should check after stopping the car immediately after pulling over when the oil light comes on, after checking oil level obviously
Old 01-10-2014, 06:37 AM
Moderator
snobordboy's Avatar
If you can't find it by Saturday, shoot me a PM and I will go take a picture on an SH block I have sitting in my garage.
Old 01-10-2014, 09:33 AM
minilogoguy18's Avatar
Oil pans don't get dented on later year Prelude's, they use an aluminum pan, it cracks or breaks instead.
I don't see how you can't find the oil sending unit, they look the same on every single Honda engine, single wire sensor with a rubber boot over the connector. You should be checking oil pressure at this location of course.
Old 01-10-2014, 01:24 PM
The sending unit is prolly not the problem
Old 04-22-2014, 04:38 PM
J.R
J.R's Avatar
Ok well I got the oil changed, new filter, and new Oil Sending Unit.
So far no more Oil light !
oscar112709
04-18-2019 12:52 AM
TegraD
03-25-2010 06:12 PM
xlee08
10
04-01-2008 02:00 PM
Funkin Flux
05-05-2006 07:35 AM
Funkin Flux
05-03-2006 10:32 AM
Quick Reply: oil pressure light comes on
