clutch slave cylinder
Old 01-02-2014, 08:01 PM
moarlow95ex's Avatar
Default clutch slave cylinder
Can someone post a picture of their slave cylinder when its fully open. my clutch feels kind of soft and I want to know if my slave cylinder is opening all of the way or if my clutch needs to be bled.
Old 01-02-2014, 08:20 PM
B_Swapped93's Avatar
Default Re: clutch slave cylinder
open,,, ? it pushes a rod against/into the clutch release fork that's how it operates and why not just bleed it takes a few mins. Look at the CMC and CSC to see if they're leaking easy to tell.
Old 01-02-2014, 08:23 PM
yes I know open pushed whatever. how far is the rod supposed to be pushed?
Old 01-02-2014, 08:28 PM
There is no 100% measure meant pedal adjustment play into it so I can't give you an exact mm spec. However a 100% test is can you go threw all the gears when the car is on and parked with your foot on the clutch without it getting stuck/not going in. if it has issues doing that bleed it and adjust the pedal.
Old 01-02-2014, 08:33 PM
it will not go into 2 3 or 4 when it is on and stationary.
PaulMc
05-18-2014 05:04 PM
krysted9354
12-30-2008 09:19 PM
b16a4
11-18-2006 11:04 AM
MechEng
07-16-2005 12:06 AM
Quick Reply: clutch slave cylinder
