car wont start
Old 12-25-2013, 05:14 PM
onemanwolfpack's Avatar
Default car wont start
I have a 91 civic with a b18a. The car started "missing" about 2 years ago when I parked it. Now I went to start it up again and it will crank over and try to start ONLY when you first turn the key on and let the fuel pump prime. The car seems to getting fuel because you can smell it and the plugs are wet. I cant tell if its getting enough spark because i cant crank it and watch the plug at the same time.
Im thinking its a distributer issue...?
Old 12-29-2013, 01:17 PM
Default Re: car wont start
Thanks for all the suggestions but I got it figured out.
Shot alittle starting fluid in it and fired right up. Now it starts up every time, no problem.
Old 01-01-2014, 05:24 PM
fresnoboy's Avatar
check fuel.
Old 01-01-2014, 07:04 PM
I checked the map sensor today and sure as ****, it was bad. Replaced that and now the car runs good but will idle serge.
Old 01-04-2014, 06:22 PM
I think I narrowed down the idle surge to the fast idle valve. Im gonna take it off tomorrow and clean it to see if it fixes the problem.
MilFhunter001
06-01-2010 06:55 AM
sohcVTEK
06-18-2006 08:44 PM
photec2
07-17-2004 03:48 PM
jdm5lughatch
05-14-2004 07:37 PM
Quick Reply: car wont start
