HONDA CRV COLD START HELP!!! VIDEOS
Old 11-04-2013, 08:33 AM
Dc2_ShowStopper's Avatar
Default HONDA CRV COLD START HELP!!! VIDEOS
Hello Fellow Techs
This is for my mother Crv she been having problems starting it up, When its cold outside.
Its 1999 Honda Crv Stick Shift. 194,000
Everything Stock,
We changed the Battery (Brand New)
*Distributor, Cap, Rotor, ICM
*Spark Plugs
*Ngk Wires
Im in jersey and this problem only occurs when its cold outside 55-60 degress. It makes a screeching noise car wont start up , after a while it turns on.
Any help would be great. And im sure someone else could benefit from it thanks !!
Old 11-04-2013, 09:03 AM
dogbiscuit's Avatar
Default Re: HONDA CRV COLD START HELP!!! VIDEOS
I would check the starter first. since it doesn't even sound like it's turning the engine over.
could be that the starter is going out or the teeth on it are messed up. weird that it's only when it's cold though.
could a bad ground cause something like this?
Old 11-04-2013, 09:53 AM
PhilStubbs's Avatar
Only thing that comes to mind is the teeth on the flywheel are messed up. Could possibly be the starter though. This is a tough one to diagnose through the internet. Maybe pull the starter and look through the hole at the flywheel teeth and also take the starter to a parts store while it's out and have it checked. Maybe it's binding and the gear isn't extending far enough to contact the flywheel.
Old 11-04-2013, 10:08 AM
im looking into the starter next, i have another oem one, im hoping its that. I will take a look into all the grounds.
Old 11-04-2013, 10:09 AM
Im test the starter tomorrow i have a replacement. Ima just work my way from their.
Old 11-04-2013, 11:13 AM
any other opinions ????
Old 11-04-2013, 01:26 PM
careawholelot's Avatar
starter
Old 11-05-2013, 11:26 AM
dogbiscuit's Avatar
it wasn't the starter? did you check the teeth on the flywheel that phil suggested? you can get a better look if you jack the car up and remove the 4 bolts holding the lower dust cover on over the flywheel you could see the teeth then.
Old 07-20-2014, 09:42 AM
It was the starter everyone
wiredzone
12-18-2009 02:46 PM
Honda13
05-13-2009 08:36 AM
po0tie
02-17-2008 09:46 AM
tjohnson329
01-02-2006 05:15 PM
AmplifiedGSR
01-28-2004 11:48 AM
Quick Reply: HONDA CRV COLD START HELP!!! VIDEOS
