Integra Clutch pressure issue with bleeding issue
Old 11-03-2013, 10:57 AM
bhergh's Avatar
Default Integra Clutch pressure issue with bleeding issue
This is a 1999 integra ls if it matters.. I'm having issues with bleeding the clutch after changing the clutch master cylinder. I have tried all the methods and suggestions I have found online. Nothing comes out when I am trying to bleed it at the csc valve . I adjusted the new cms to match the distance of the stock one. What am i doing wrong.
The methods I used were vaccum pump. Person assisting me while I opened bleeder. Self bleed technique like the youtube ericthecarguy did..
is it a bad clutch slave cylinder?
Old 11-03-2013, 11:20 AM
B_Swapped93's Avatar
Default Re: Integra Clutch pressure issue with bleeding issue
is there a leak anywhere in the line ? or on the SC
Old 11-03-2013, 11:46 AM
bhergh's Avatar
the csc is not leaking as i can feel or see. As well as the line.
Old 11-04-2013, 04:52 AM
tamboo's Avatar
did you hold the pedal down while bleeding?
pre-bleed the master cylinder?
i forgot to do the latter so spent a good hour pumping/bleeding
before getting decent results.
loosen locknut c and spin it to the end of the thread
then keep turning with a wrench til pedal contacts clutch switch.
http://s23.postimg.org/ssyc5zwk9/page0334.jpg
Old 11-04-2013, 08:02 AM
bhergh's Avatar
Since it has snowed I think I'm just taking it to the shop.. but it could be the way I bench bleeded.. but one hour without bench bleed I didn't think it would be that long.. thanks again for your help
Ek9b20v
12
03-31-2013 01:21 PM
ducsaim
01-14-2011 12:17 AM
GreddyTegra
09-07-2009 08:50 AM
slwcivic
06-25-2006 05:42 PM
MugenHonda
06-27-2005 08:00 AM
Quick Reply: Integra Clutch pressure issue with bleeding issue
