Engine Codes!!! Need some insight
Old 10-28-2013, 01:51 PM
RIPTEC's Avatar
Default Engine Codes!!! Need some insight
1999 honda accord 2.3L vtec F23A1
Hey guys, I just fixed a code for my vtec malfunction, and now I have some new codes to figure out. Here they are...
1. P0706 - Open in transmission range switch circuit
2. P1456 - EVAP emission control system leak detected (fuel tank system)
3. P0420 - Catalyst efficiency low-bank 1
4. P0430 - Catalyst efficiency low-bank2
Has anyone encountered any of these codes and can pass on some insight on how they fixed them? Also, for coes 3. and 4., I replaced bank 2 o2 sensor about 2-3 months ago and just replaced bank 1 o2 sensor the other day. I was only throwing the bank 1 o2 sensor code before this.
Any ideas??? Thanks guys in advance for any help.
Old 10-30-2013, 10:22 PM
RIPTEC's Avatar
Default Re: Engine Codes!!! Need some insight
bump
Old 11-02-2013, 09:32 AM
Lost Again's Avatar
Clear them....be sure the gas cap is tight. Drive and see which codes come back.
Also, for a 4 cyl....bank 1 is all that should show up.....bank 2 is only for the 6 cyl.
Old 11-06-2013, 07:21 AM
Redtop01's Avatar
96 honda accord lx 150,000 miles 4 cyl 4 door mechanic says the code shows I need fuel vapor vent pressure sensor, now he didn't seem to think I had to get fixed right away . He had just put in a ECM A week before. I did replace gas cap and took battery cables off to reset ECM, but light came back on. Will it hurt to wait to get fixed. Car drive good right now. Wasent sure this is where to put this question, if it's wrong ,sorry. In advance thanks for any help
Old 12-10-2013, 07:13 PM
RIPTEC's Avatar
So, I need to get the evap code fixed. Has anyone ever replaced the canister and 2 way valve, and is it hard to do?
Old 12-11-2013, 12:21 AM
MM Gruppe B
MAD_MIKE's Avatar
I have always been suspicious of codes popping up after a fix.
If I were you, I would go back to the area/areas I was working on and verify that I did not knock/move/disconnect any component loose.
Something I have done twice now when working near the throttle body on my '95 and '97 is I have placed just enough pressure on a junction where a vacuum hose attaches to a vacuum line to cause the line to cut the hose. Nothing serious as it was part of the air intake baffle/resonator control assembly, but still I did not notice the issue until a later date when doing routine maintenance.
May be well worth it to just to a once over on all the electrical connectors and vacuum hoses in the region.
cliftarosa
06-23-2020 04:01 AM
oodie
11-16-2008 04:46 PM
BAZ
04-28-2004 08:55 AM
cyrixvsp2
06-10-2003 05:02 AM
6SPD_EK
02-20-2002 02:52 PM
Quick Reply: Engine Codes!!! Need some insight
