Stiff brake pedal
Old 10-26-2013, 11:14 AM
rizzuto_usmc's Avatar
Default Stiff brake pedal
I have a 1995 honda civic ex with abs and I recently replaced the brake booster because the pedal was very hard to push but after replacing it and bleeding the brakes the pedal is still hard. Could the master cylinder possibly be bad?
Old 10-26-2013, 11:19 AM
jdmh22eg2's Avatar
Default Re: Stiff brake pedal
replace your booster check valve(if it is there) if its not there then there is your problem.
Old 10-26-2013, 11:44 AM
TripleLude's Avatar
Make sure the check valve is not on backwards. Basically, you have taken the power out of the power brakes. Vacuum air from the intake manifold provides the power.
Old 10-26-2013, 02:11 PM
Fish Twig
tony_2018's Avatar
You guys have a picture of this check valve?
Old 10-26-2013, 06:55 PM
TripleLude's Avatar
Something similar to this:
I put one on backwards on my Prelude and it didn't have power brakes. After swapping the position back, it had power brakes again.
Old 10-26-2013, 10:33 PM
vitamin_c95's Avatar
follow the main booster hose. I think its about a foot from the booster. The plastic valve
Old 10-28-2013, 04:55 AM
replaced the check valve and it fixed it. thanks.
JONESER
05-18-2010 08:52 PM
crazyboy
10
09-15-2009 08:04 PM
3gcvcd16
06-25-2008 09:55 AM
Del_Sol_s
27
03-04-2006 06:49 AM
FourthGenHatch
07-09-2003 05:51 PM
Quick Reply: Stiff brake pedal
