Lower timing belt cover b20vtec
Old 10-20-2013, 05:39 PM
Jay Jackson's Avatar
Default Lower timing belt cover b20vtec
Does it matter which timing belt cover to use b16a or the one that came with the B20b bottom end or do I need one from an ls block. Reason iam asking because my cam gear timing is off a little bit every time I try to align it its still off about a tooth iam using the B20b lower cover.
Old 10-21-2013, 05:19 AM
kyden's Avatar
Default Re: Lower timing belt cover b20vtec
if you're using a usdm obd2 oil pump, use an obd2 cover. (doesn't matter which b series)
if you're using a jdm or obd1 usdm oil pump, use an obd1 cover.
if you're doing mechanical timing, i would remove all covers and use the mark on the oil pump.
Old 10-21-2013, 10:42 AM
Iam using a usdm gsr oil pump so use a usdm gsr cover? Or like you said set it with the oil pump mark alright ill give it a try with out the cover thanks for the info.
Old 10-24-2013, 05:49 AM
negusjuda's Avatar
usdm and jdm and edm and every other dm is the same the difference is in the years obd1 needs a obd1 cover obd2 needs a obd2 cover the oil pumps are different hence the difference in covers
Old 10-26-2013, 06:56 PM
Found something else out I read one of the threads off of Honda Tech about the B20vtec timing is always going to be off a little so I should be good now I have adjustable cam gears .
Old 10-28-2013, 06:25 AM
kyden's Avatar
the adjustable cam gears aren't gonna fix your timing marks being off.
Old 10-28-2013, 06:40 AM
Seagull Management
94EG8's Avatar
JDM OBD2 covers are the same as OBD1 because they don't have a CKF sensor.
boosted k20
10-16-2017 11:11 PM
bunkrd you
09-11-2011 10:45 AM
NA JDM GSR
08-01-2010 09:17 AM
n0y
02-18-2010 01:19 AM
DEIVIONCRX
04-28-2009 09:53 AM
Quick Reply: Lower timing belt cover b20vtec
