Engine has no low end power
Old 11-19-2013, 05:14 AM
  #51
Freemananana's Avatar
Default Re: Engine has no low end power
Originally Posted by longhammer
your gonna snap lol but the swaping of engines do I need to extend and switch the wires for the tps?
the plugs on the left all look as if they will just hook together except one square one Ive read over all those schematics on wiring and the plugs are my hang up, I get what I have to do at the ECU with de pining and soldering so with the DX harnesses how many wires have to be cut and modified?
They will need to be extended. Definitely read some write ups. The TPS and the IACV need to be extended I think.
Old 11-23-2013, 09:44 AM
  #52
zrickety's Avatar
You've got your work cut out. You could run the 1.6 by swapping intake manifolds and use the DPFI. You'll still get gains and it's a much easier swap. I had good luck with that setup in a crx.
Old 11-25-2013, 03:43 AM
  #53
A DPFI 1.6 haha. Yeah, I guess there would be gains. But OP, you do have your work cut out for you.
udechukwu
07-11-2011 01:26 AM
4LugR
11-29-2005 05:25 PM
HotWheelz
05-01-2003 10:06 AM
dirtySOHC's
02-14-2002 01:07 PM
Quick Reply: Engine has no low end power
