95 Civic Ex - shaky acceleration, low idle, 3 CEL codes
Old 10-13-2013, 06:15 PM
JCORTES's Avatar
Default 95 Civic Ex - shaky acceleration, low idle, 3 CEL codes
I Have a 95 honda civic ex
i have a zc block
the car start but when i accelerate it does it a bit shaky also when it is returning to idle position sometimes i will shut off sometimes it sounds like it will but does not
i have 3 check engine codes which are
code
3: map censor.
15: ignition output signal.
41: primary oxygen heater.
Old 10-13-2013, 06:38 PM
Former User's Avatar
Default Re: Need Help fixing some Problems with my 95 Honda Civic Ex
What head and ECU?
If you reset the ECU to clear codes, do all 3 codes return?
Old 10-13-2013, 06:52 PM
JCORTES's Avatar
i have a p28 ecu and for the head am not sure! but its a vtech!
not sure how to reset all the codes!
Old 10-13-2013, 06:57 PM
Clear here to figure out what head is on the block.
Click the codes link in my signature to learn how to clear codes.
Old 10-13-2013, 07:03 PM
JCORTES's Avatar
ok i have a p08-1 and the year is a 92
Old 10-13-2013, 07:06 PM
Default Re: 95 Civic Ex - shaky acceleration, low idle, 3 CEL codes
Old 10-13-2013, 07:07 PM
JCORTES's Avatar
Can you explain what your trying say?
Old 10-14-2013, 07:31 PM
Just showing you the head associated with the head code you posted.
Old 10-14-2013, 10:06 PM
crazyhouse2011's Avatar
Wrong ECU, partner. And i would get that map sensor fixed too if i were you. Good luck, friend.
Old 10-15-2013, 09:46 PM
chopperkiller's Avatar
how can u troubleshoot the iat sensor to clear the code 10?
Old 10-15-2013, 11:01 PM
Solster's Avatar
if the p28 ECU is chipped and tuned it should work fine.
Old 10-16-2013, 07:38 AM
any help on troubleshooting the iat sensor?
Old 10-21-2013, 07:44 AM
JCORTES's Avatar
the ecu is not chipped or tunned. So their no way for the car to work properly with the p28 ecu?
Old 10-21-2013, 07:46 AM
JCORTES's Avatar
Chopperkiller go on YouTube and type in Honda civic map censor and you will find a video on how to check the map censor
Old 10-21-2013, 08:18 AM
Technical Hero
HondaPartsHero's Avatar
Old 10-22-2013, 07:34 AM
JCORTES's Avatar
Icon2 Re: 95 Civic Ex - shaky acceleration, low idle, 3 CEL codes
The codes are still their even if i reset the ecu!
Also how would i know what distributor would i need for the head?
Old 10-22-2013, 09:00 PM
Solster's Avatar
there should be a code stamped on your Distributor ot's on one of the 3 ears the mounting bolts go through.
as long as the dissy you have mounts correctly you need the same code.
on my 97 GS-R B18C1 the code is TD-86U
on a D16Z6 the code is TD-44U
Old 10-28-2013, 08:06 AM
JCORTES's Avatar
It's a zc block but the head is a 92 P08-1
It's because I swapped out the motor it had that's why am not sure because the old distributor doesn't fit it
4g4dcruisin
17
03-18-2010 08:49 AM
andrewk
02-02-2010 10:48 AM
what1118
11
12-25-2007 06:06 PM
pip9
12-28-2004 02:29 PM
Quick Reply: 95 Civic Ex - shaky acceleration, low idle, 3 CEL codes
