HELP! Removed spark plug and oil drained into engine
Old 10-13-2013, 01:15 PM
ccauthe's Avatar
Default HELP! Removed spark plug and oil drained into engine
I went to do a compression test on my car today (1993 honda accord) and removed the spark plug wires, noticing there was a lot of oil in the spark plug hole/well, I still proceeded to remove the spark plug (against my better judgement). Now oil has drained down into my engine... Is there anything I can do!???
ccauthe is offline
Old 10-13-2013, 01:20 PM
Robs_B18c's Avatar
Default Re: HELP! Removed spark plug and oil drained into engine
Change your valve cover gasket and o-rings. Put the spark plug back in start it up and let it burn off.
Robs_B18c is offline
Old 10-13-2013, 06:35 PM
motoxxxman's Avatar
x2
and after you burn it off from driving for a bit, install new sparkplugs
motoxxxman is offline
SeanaK
06-24-2014 03:22 PM
VTEC_Du_Ma_Mai
09-06-2008 11:08 AM
VTEC_Du_Ma_Mai
09-05-2008 01:41 PM
B18CRacer
07-14-2004 05:06 PM
gixxer6
10-29-2002 01:10 PM
Quick Reply: HELP! Removed spark plug and oil drained into engine
