95 Del Sol S SRS Light
My SRS light is on. I jumped the two pin connector to get the code. The SRS light Comes on for 6 seconds goes out and then after 3-4 seconds it comes back on and stays constant. It doesn't flash a trouble code. Any help would be greatly appreciated. Thank you.
Re: 95 Del Sol S SRS Light
Yes, but after resetting it might stay off 1-2 days or come back on the next time I drive it. When I try to read the code it's always the same. The SRS light comes on for 6 Seconds then goes off and then after 3-4 seconds it comes on constant. Thanks again.
There are a variety of possible causes for this problem. You need the factory service manual for you car. It details a series of electrical tests used to pinpoint the problem.
It came back on, on the way home. Checked it again still no codes. Reset it again last night and on the way to work this morning it came back on. To check the codes you use the same 2 wire yellow plug with gray wires that you use to reset it, Right?
deanwashere
07-25-2018 04:28 AM
Reaccion
Honda Civic (2006 - 2015)
24
10-20-2017 11:26 AM
RATEDR
07-13-2009 11:51 AM
