Some help from you CRV Gods!
Old 09-29-2013, 08:35 AM
sho_shane's Avatar
Default Some help from you CRV Gods!
Ok so I bought a 98 CRV that was totaled. Not a bad CRV and I'm trying to put this thing back together and need a little help finding stuff I'm having a hard time finding.
The CRV need a new Sub Frame witch I can see is a bolt in, I need to know what all years of Sub Frames I can use for it?
I also need to know maybe even a link to where I can buy a FULL urethane susp kit for the CRV? The rear Lower Control arm Bushings are blown out and I want to go ahead and replace all of the bushings with Urethane if I can.
Any and all help would mean the world and I hope everyone has a blessed day.
Old 09-30-2013, 02:20 PM
kiseliok's Avatar
Default Re: Some help from you CRV Gods!
Front or rear subframe? I have the rear one sitting around that I might be willing to part with..
Old 10-01-2013, 03:46 PM
jdm_bones's Avatar
1996-2001 are all the same, as for the bushings inside the control arms, i recomand just buy a used control arm on line, might be cheaper, if not there is a company called energy suspention, or es, but i hear that fitment is hit or miss. GOOD LUCK!
Old 10-01-2013, 07:43 PM
www.megameet.org's Avatar
Moog parts are very good for suspention
Old 10-09-2013, 08:00 PM
85_sr_seville's Avatar
http://www.hondapartscheap.com/index.php?p=home is a good place for new factory parts. 2000 Integra type R fits the Rear and 99-00 Civic SI for the front.
Chris
naahnaah
Suspension & Brakes
06-01-2008 12:18 PM
DA9_TypeR
04-24-2006 06:28 AM
MrPink69
Suspension & Brakes
08-05-2005 07:03 AM
Jdm93civic
08-24-2003 10:47 AM
Quick Reply: Some help from you CRV Gods!
