How to: Quaife 88-91 2.8 LTL Quick Rack & Pinion into 92-95 Steering Gearbox
Old 11-11-2013, 01:09 PM
  #51
10cjennings's Avatar
Default Re: How to: Quaife 88-91 2.8 LTL Quick Rack & Pinion into 92-95 Steering Gearbox
There isn't any SCCA SOLO in South Florida, events are run by ERSCC.
Those concrete barriers are not usually there, get a tire in the grass and you're probably hitting them.
I noticed little difference between a couple set of RA1 take offs and the rivals. 40TW slicks are a totally different level tho, more so then I expected.
Old 11-11-2013, 05:14 PM
  #52
Xian's Avatar
Yup... Before I took my racing hiatus, I'd only run Hoosiers for about 5-6 years. Good r-comps are an amazing thing.
Regarding Extreme Perf tires and the lower end R-comps... Their ultimate grip braking and cornering is similar. When the braking and turning are combined is where I see the lower end r-comps beating up the extreme Perf tires. There's a notable difference there, IMO.
Old 02-10-2014, 03:21 PM
  #53
Small update....
After the first week and event the rack developed a little play. I had replaced all the rack guide components as well, so I thought they might break in and loosen up.
The FSM says up to 10mm of play is within spec, however I preferred when it had basically none. This is adjustable via the rack guide screw, however it's impossible to access with the rack in the car with normal tools. Pulled the rack and went over it. Everything looks to be holding up perfectly well. Welded pinion shaft looks perfect, as well as the rack gears teeth.
Old 04-01-2014, 01:04 PM
  #54
ericroan's Avatar
where did you get your quaife quick rack kit?
I know there's a lot of vendors out there, but just want to know where did you get yours.
I'm thinking about to do this as well.
Old 04-01-2014, 01:15 PM
  #55
Found it in forum classifieds for a deal. I remember there being a couple sellers on eBay with them listed.
Old 04-02-2014, 09:47 PM
  #56
Homosexual by choice
exgr's Avatar
speaking of quick racks... In Japan Honda S2000 has a VGS model and it has a very fast variable ratio rack. I briefly drove one it's pretty neat. we had imported a VGS model S2000 to USA in 2012.
Old 11-17-2014, 08:14 AM
  #57
Selling the rack
https://honda-tech.com/sale-10/quafi.../#post50062389
IdotheSHOCKER
06-24-2021 04:13 PM
STN_Pat
04-09-2007 02:38 PM
20_sec.hatch
Texas -OK -LA (Sales)
03-01-2006 08:48 AM
sickdoo
02-06-2005 11:20 PM
Quick Reply: How to: Quaife 88-91 2.8 LTL Quick Rack & Pinion into 92-95 Steering Gearbox
